Plans for non- appleseed reactor?
Old 11-23-2007, 04:48 PM
Rushmore X's Avatar
Rushmore X
Rushmore X is offline
Greetings,
there are lots of plans out there for appleseed style reactors, but I hear several people are using mechanical mixing instead of pumps, and not using water washing, but using a drying agent. (can't remember the name, senior moment... used in diapers) supposedly higher quality Biodiesel is obtained. Any ideas where I can find plans?
thanks
Old 11-29-2007, 07:56 PM
AndysFords's Avatar
AndysFords
AndysFords is offline
The easiest way is to get a 55 gallon drum, weld a galvanized pipe fitting in the bottom, screw in a pvc valve, then you can buy or build a 55 gallon drum mixer. I built mine out of an old greenhouse fan. I took the fan, cut the actual fan off, extened the shaft, cut the fan blades down to about 6 inch diameter, and set the whole deal over in a drum, instant biodiesel reactor. Total cost, less than $50 in the whole deal.
Old 11-30-2007, 11:49 PM
kennedyford's Avatar
kennedyford
kennedyford is offline
The dry method is called magnesol. You will need to use 2 percent by weight unless you evap the methanol and then your down to 1 percent per weight. You will need to pump the bio off the top in order to leave the heavy moisture ladden magnesol on the bottom and dump out later.
Rushmore X
Bio-diesel, Propane & Alternative Diesel Engine Fuels
05-23-2010 03:03 PM
Rushmore X
25
01-24-2010 05:25 PM
Gun-Driver
04-12-2007 11:15 AM
Pele
01-01-2007 11:37 AM
RDC F250 7.3
08-13-2006 11:16 AM
Quick Reply: Plans for non- appleseed reactor?
