Another timing belt Q
on
The cover is mostly for safety, so you don't get articles of clothing or bodily appendages caught in the belt when working around a running engine. It's also to protect the belt.
When I was racing mini-stocks, we never ran the cover. We also ran adjustable cam pulleys so we needed to be able to access them easily. You shouldn't have a problem leaving the cover off...
cool, thanks i am glad you re-assured me. When i took the cover off there was more mud/dirt on the timing belt than there was around it and on the serpentine belt. i guess the cover trapped all the debris behind it. Now i can keep an eye on the belt and keep it all clean and free of debris.
Road debris and fingers. One will hurt the belt and one will hurt you. They did not put the cover on for fun. The engineers are always looking to cut material costs, and they did the minimum for the belt cover. The original covers were made of sheet metal, and were HARD to get off/on because the mounting tabs were just not lined up with the holes in the head/block. And you had to get them past the crank pulley, water pump pulley etc. Maybe I should have removed the crank pulley first...
If you made a million or so engines, and could save 50 cents on each one... you'd do it. They did. And they still put the cover on. Do your own thing. tom
BTW, i took the truck out yesterday. Played in the mud and woods. Drove it for about 8 hours Friday. No problems, no mud even got on the belt or near it the mud was about 18 inches deep. I think the air movement from the fan keeps most of the crud from getting near it. Anyhow, just my personal observation.
oldfordcoupe
10-15-2009 05:16 PM
Critterhunter
1983 - 2012 Ranger & B-Series
09-10-2002 09:21 AM
