1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2002 f250 psd died
Old 11-15-2007, 11:31 PM
jtmiller's Avatar
jtmiller
jtmiller is offline
Cool 2002 f250 psd died
going down road at 75mph truck just died and will not start changed cps still wont start last dtc codes po344 po340 p1aee pooo8 po8a6 poo27 p1011 if have any info. please let me know asap thnks jtm
Old 11-16-2007, 08:43 PM
F350-6's Avatar
F350-6
F350-6 is offline
P0344 CMP Sensor Circuit Intermittent
P0340 CMP Sensor Circuit Malfunction
I don't have the other codes listed in my service manual, but I'm starting to see a pattern here. Where did you get your CPS? I've heard of ones from the auto parts stores going bad as soon as there put in.
Old 11-18-2007, 02:23 PM
jtmiller's Avatar
jtmiller
jtmiller is offline
Thumbs down
had had a spare cps and then ckecked it again through a friends truck and it worked fine still down any help would be appreciatded thanks jtm
Old 11-18-2007, 02:37 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
fuel pump and fuel filters?
Old 11-19-2007, 07:48 AM
NS F250's Avatar
NS F250
NS F250 is offline
Check the wiring to the cps. I had a similar problem that ended up being bare wires at the cps plug. Also, make sure the connection is clean and use some dielectric grease.
Old 01-27-2008, 02:58 PM
2002 superduty's Avatar
2002 superduty
2002 superduty is offline
same problem with my 2002 f-250 diesel. dtc codes p0008, p1aee, and p08a6. any luck with your truck? i have changed throttle position sensor, cleared problem for abuot 3 weeks then problem reappeared. any help or other info greatly appreciated.
Old 09-22-2008, 04:38 PM
Jim Simmonds's Avatar
Jim Simmonds
Jim Simmonds is offline
Hi what did your problem end up being?
I also have the P0008 and P1AEE codes
samthemountainman
2004 - 2008 F150
02-18-2012 02:46 PM
itsunday25
07-07-2011 05:22 PM
jcahicks
03-24-2011 11:13 PM
FI460
01-12-2011 06:48 AM
SR72
09-07-2009 07:43 PM
Quick Reply: 2002 f250 psd died
