Veg oil and Gasoline Mix?!?!?!
Old 11-14-2007, 09:42 AM
Wheatina's Avatar
Wheatina
Wheatina is offline
Came across a post in a biodiesel forum talking about what this guy is doing. What do you all think of this...is this the "secret" to "Diesel Secret?"
http://www.oilcrusher.5u.com/
Old 11-14-2007, 11:10 AM
adambomb's Avatar
adambomb
adambomb is offline
i know some peole with veggie converted mercedes add 1/2 gal of gas to there tank of veggie. i have never done this in mine but saposivly works for really cold weather.
Old 11-15-2007, 12:06 PM
CanadianSmokie's Avatar
CanadianSmokie
CanadianSmokie is offline
Yes, the RUG thins out the oil and also produces a chemical change to the oil so that it does not 'string' when pushed through the injectors. This will help avoid coking of the injectors and rings. It's also a good idea to add a cetane booster to the mix to help smooth out the combustion process.
Gas has been a winter additive to diesel for decades. It helps to thin it out and prevent clouding in the cold.
Old 11-15-2007, 10:22 PM
AndysFords's Avatar
AndysFords
AndysFords is offline
I normally run about 20% #2, 75% WVO, and 5% Reg Unleaded. My truck still doesn't have the power it has with straight #2, but a lot more than it did with straight WVO. I do know that an old volkswagon diesel a friend of mine has recommends up to 20% gas mixed with the diesel in the winter, so obviously you can go up pretty high with it. I am considering switching from gas to just putting propane injection on my truck, but I'm not sure about it.
Old 11-19-2007, 10:44 AM
Phydeaux88's Avatar
Phydeaux88
Phydeaux88 is offline
Do you have any proof that gas "produces a chemical change in the oil (sic Veg Oil)". I do not believe that is possible.
Old 11-19-2007, 08:07 PM
firemediceric's Avatar
firemediceric
firemediceric is offline
When I make my blend I add 5% gasoline.
The old Mercedes literature advised adding some gasoline to the diesel fuel in the winter time.
Old 11-19-2007, 08:47 PM
AndysFords's Avatar
AndysFords
Why would it have to produce a chemical change, its not supposed to produce a change, just thin it down, gasoline is very thin, as opposed to veggie, which is extremely thick. It makes flow and filter better.
Y2KW57
22
08-26-2020 10:35 AM
Alex from GA
01-05-2016 02:01 AM
Tim Hodgson
35
10-12-2015 11:20 AM
PrinceValium
2009 - 2014 F150
30
10-28-2012 10:24 PM
Secret Agent 069
Southwest Region
02-23-2008 09:16 PM
Quick Reply: Veg oil and Gasoline Mix?!?!?!
