bad ignition module symptoms?
Carrying a can of keyboard duster and holding it upside down and blasting the module
will get you off the side of the road quicker if it fails due to heat failure!! Just try 20
seconds or so to start and see if it cranks back up. It also works for coils and other
electrical components and even fuel line heat(vapor lock) problems. So keep a half
empty can in your truck and wait 7 minutes instead of waiting an hour for it to cool!!
I super glued a heatsink to the back of mine and ran a intake tube to the distributor
area to get a blast of cold air from the radiator support blowing on to it.
Originally Posted by fordinmudd
do ignition modules act up and have symptoms when there starting to go bad?or do they just die and thats it?
http://www.PerformanceDistributors.com
__________________
FTE Sponsor
Performance Distributors
FTE Sponsor
MustangGT221
28
08-14-2016 09:22 AM
Superdave
42
11-21-2010 02:00 PM
