I Really Need Help!!!!!
Originally Posted by runitsdafuzz
this might sound like an odd question but does anyone in the rochester/chili area willing to come look at my truck and possibly help me fix it im only 17 dont know very much but willing to learn as much as i can. thanks
year
FI/carb
motor
model
And anyting else we need to know.
1990 f250 fuel injected i was told its a 351 windsor havent checked the numbers yet, i have smoke comen out of the valve cover when its being revved or when im driving smoke pours out at about 2700 and up but when im in about 4th and 5th it kinda calms down cause of low rpms i was told multiple things like its the rings valves and some other stuff and i dont have a lot of money, i was going to do a compression test but couldnt because of weather and not having a big enough garage to work in and the fact it doesnt run because of possibly the alternator so weather hasnt been on my side and now i dont have a compression tester because it belongs to my teacher and i had to give it back.....so idk what to do anymore.
1) Go for the PCV valve idea first. It is rightly called the Positive Crankcase Ventilation Valve, and is there because some blow-by past the piston rings can happen, and it controls the buildup inside the engine by evacuating it to the intake manifold - right about when you have hi vaccuum, such as at sustained highway speeds. They often plug up with gunk over time.
2) Do the compression test as soon as possible, because you definitely have some blow-by, the question is HOW MUCH.
3) Take a look at your air filter. It could provide an indication of how much blow by has happened over time. They don't just fail overnight. If it's black with crud, it's a good time to spring for another one. To some degree they are cleanable, you'll have to see it to judge. May I suggest carb cleaner, compressed air, gloves, goggles, and the great outdoors... (It'll make a mess) *DON'T use gasoline.
4) If you are planning an oil change, you can try ONE pint of diesel in the oil before it is changed, run it for ten or twenty minutes, then drain it out well. This may flush most of the crud out of your engine, but if you do this - a new oil filter is a MUST HAVE, because it will be filled up with it all.
Old timers will tell you - DIESEL FUEL will clean out an engine better than ninety nine percent of what is sold in parts stores for three times as much money. I believe it is true. But you can't run it in there for very long. Twenty minutes tops, followed by a complete drain.
It may also have a long lasting effect in an engine that has been severely abused. In the valley area under the intake manifold - there is often a thick layer of built up crud that can only be loosened up gradually. You can't see it without removing the intake, so watch your OIL COLOR if you try this, for a while afterward. It could increase your need to replace the filter and oil if there really is a HUGE bunch of stuff in there.
But you might still save the engine!
I am not one to recommend "QUACK" strategies, by the way. Ask around about this, and see what others here say about it.
i was going to suggest this to but i figured someone would say something bad about it but this does work i have done it to one of my trucks
