Georgia Chapter Join Chapter, Leader: ChiefM SPONSORED BY:
99 Explorer PO171 codes
Old 11-05-2007, 07:59 PM
FAPP's Avatar
FAPP
FAPP is offline
I currently own 10 Fords from 1965 to 2004. By far the 99 Explorer (127K) has given Ford a black eye. My check engine light is on again and the OBD II code is PO171 (too lean). I replaced O2 sensors on one side and the light appeared again a couple of weeks later. I cleaned the MAF, PVC valve and looked for vac leaks. Fuel filter was changed 12K ago. The engine is hard to start in the morning. Once started, it revs up and down for a few seconds and then idles. I have read online that it may be bad intake o-rings. Any similar experiences? Any help would be appreciated.
Old 11-05-2007, 09:59 PM
Gevans17's Avatar
Gevans17
Gevans17 is offline
Po171
Look for leaks around the upper intake seals, damaged pcv hoses, vacuum tree at the back left, depending on the year, lower intake around the front or back corners. Also look for cracks, loose clamps on the intake air tube in between the ribs.
Old 11-06-2007, 05:14 PM
skidooman's Avatar
skidooman
skidooman is offline
I had the same problem with my '99 Explorer, It was the intake gasket. Ford had extended the warranty on that particular part so it was done on warranty, but that was a couple of years ago.
toddrochester
10-30-2011 07:45 AM
jaystersj
01-16-2009 11:03 AM
jmwhelchel
09-19-2008 04:01 PM
enkaarob
1983 - 2012 Ranger & B-Series
10-31-2007 09:25 AM
99UAV
02-27-2006 09:51 AM
Quick Reply: 99 Explorer PO171 codes
