2007 expedition suspension modifications and aftermarket tires
Old 11-03-2007, 11:25 AM
nfntruth's Avatar
nfntruth
nfntruth is offline
I haven't been able to find any other info so I am posting what I have found. My truck is in the shop right now having the lift kit installed. I went with the one from Truxx, which I got from Fat Boys garage. (Forum sponsor). I will post the new pics in my gallery when I get it back. As far as tires, The absolute largest you can fit without cutting or lifting are 305/65/17. That adds less than an inch in diameter, but a few inches in width. They will fit on a 4X2 with absolutely no rubbing, and that was with full suspsension travel. There isn't much room though, less than a 1/4 inch. I bought the Procomp A/T extremes, buy 3 get one free, I couldn't pass it up, and I put them on Moto Metal wheels. The road noise is tolerable, but definitely louder than the stock tires. But with the luggage rack and rain guards, its just one more noise producing add on. If anyone has any more suspension experience, post it up, I know some would like to know. Especially if anyone ran the Daystar kit, which is much cheaper than the Truxx kit. FYI, I am having it installed at Meineke, my 4WD shop wanted 600 for the install with an alignment, which was ridiculous, but Meineke is doing it with a Flowmaster muffler as well, for 480. Can't beat that.
Old 11-03-2007, 05:36 PM
nfntruth's Avatar
nfntruth
nfntruth is offline
Just picked it up from the shop, the exhaust sounds awesome, and the kit was perfect excpet one small problem, the rear brakelines are a bit tight at full extension of the rear suspension. It wasn't the limiting component in the loop, but I will replace them eventually. Here are the post lift pics.
Old 11-03-2007, 08:54 PM
montecarlo31's Avatar
montecarlo31
montecarlo31 is offline
That is weird, I figured the 4x4 and 4x2 rode at the same height but I guess not since you can clear 35s (per Truxxx) on the 4x4s. either way nice looking rig.
Old 11-03-2007, 09:42 PM
IQ9's Avatar
IQ9
IQ9 is offline
Looks good. How has the ride changed?
Old 11-04-2007, 05:18 PM
nfntruth's Avatar
nfntruth
nfntruth is offline
Not anything noticeable except the height. I think the increased width of the tires and the offset are making up for the height change. My wife has to use the sidesteps to get in now...at least now they are useful. It feels nice to me, obvious enough to be different, but not a monster truck or anything like that. I am happy with it so far, except now I may have to get a 2" drop draw bar for my hitch, booooooooo, I have a three ball straight draw bar which was perfect, we will see when I tow the trailer again, which on a side note the Expedition pulls like it isn't even there.
PS-The overall height with the basket is now 7'6". No more parking garages for me here in San Diego, they are mostly 7' or so.
Old 11-04-2007, 09:36 PM
07EXPYEL's Avatar
07EXPYEL
07EXPYEL is offline
Nice looking Expy. Where'd you get the rear mud flaps?
Old 11-05-2007, 10:20 AM
carbonmetallic's Avatar
carbonmetallic
carbonmetallic is offline
looks good, I had the truxxx lift put on mine a few months ago. It definately makes it higher. I have had a few problems in parking garages as well. Truck is probably about 6'8 now or so, I can fit in parking garages that state 6'6" or so, but I have to dodge pipes that hang down, which is what they measure from. No big deal. Once I add 33's i will have more issues. I currently have stock size Nitto Terra Grapplers, I may end up having to get new ones sooner than later, one of the tires seems to have a very slow leak. I think it may be from a slight cut in the sidewall.
Old 11-05-2007, 11:27 AM
IQ9's Avatar
IQ9
IQ9 is offline
I LOVE the Terra Grapplers. Had them on my Titan. They are the BEST!!
Old 11-05-2007, 11:33 AM
carbonmetallic
This leveling kit improved the response of the stock setup. It didnt change the ride quality any at all, but off road or on bumps and it seems to have better maneuvarability and doesnt have the nose dive like I had before when i added the brush guard.
Old 11-05-2007, 12:40 PM
IQ9's Avatar
IQ9
IQ9 is offline
The suspension better copes with the off roading or is more controled while off roading?
Old 11-05-2007, 12:51 PM
carbonmetallic
[QUOTE=IQ9]The suspension better copes with the off roading or is more controled while off roading?[/QUOTE
I dont know quite how to explain it. The suspension seems to react quicker. the recoil of the springs seems to keep the tires on the road longer.
Old 11-05-2007, 02:29 PM
IQ9's Avatar
IQ9
IQ9 is offline
Sounds like it is much more controlled. Thats a good thing. Better control better driving....or faster driving;-)
Old 11-05-2007, 07:53 PM
nfntruth's Avatar
nfntruth
nfntruth is offline
I got them at Pepboys, the size 7 or 8 molded flaps, just look at the chart and see what fits the old expys.. Think they were 30 bucks, took about 40 minutes to put them on, had to take the wheels off to do it right. Ford makes some, but they are flat, not molded and I couldnt even find a set here in So Cal, Arizona was the closest...I may put them on the front too, we will see.
Old 11-06-2007, 12:58 AM
Monsta's Avatar
Monsta
Monsta is offline
Sit. Stay.
Originally Posted by nfntruth
Is the front now higher than the rear or is it a camera "trick" with it being on an unlevel surface?
Nice combo none the less. I had a red Expy (03) once. I wanted to do the same thing you've done but use the Daystar kit.
Old 11-06-2007, 05:49 PM
nfntruth's Avatar
nfntruth
nfntruth is offline
Its a camera trick, the driveway is slanted upward, but the front lift was 3" and the rear is 2", due to the fact that the truck sits naturally higher in the rear. But the wheel well gap is larger in the front even on flat ground, but overall the vehicle is level.
Quick Reply: 2007 expedition suspension modifications and aftermarket tires
