British Columbia British Columbia
Join Chapter, Leader: sky Cowboy
4x4 issues
Old 10-31-2007, 05:46 PM
DeezDay's Avatar
DeezDay
DeezDay is offline
4x4 issues
anyone have any ideas what could be wrong with my 4X4, 93 ranger manual hubs, push button 4X4 nothing happens, push button and no lights come on, when i take the switch out and use my test light there is power getting to the switch i have no idea. Has anyone ever had this problem or have any ideas.
thanks
Old 10-31-2007, 06:47 PM
preppypyro's Avatar
preppypyro
preppypyro is offline
I would check the ranger, or some of the drivetrain forums man. There you can get alot more specialized help then in here!
Old 10-31-2007, 10:20 PM
Digger6's Avatar
Digger6
Digger6 is offline
I would say it would be the actuator on the trasfer case, the push button chevys were famous for failling
Old 11-01-2007, 10:17 PM
Bandit-1's Avatar
Bandit-1
Bandit-1 is offline
you could try testing the switch or use a jumper wire to bypass the switch
Old 11-02-2007, 11:41 AM
DeezDay's Avatar
DeezDay
DeezDay is offline
how to use jumper wire
hello, bandit i am just wondering how i would bypass the switch or use a jumper wire any ideas. and thanks alot for everyones help.
Old 11-03-2007, 08:32 AM
preppypyro's Avatar
preppypyro
When you press the button can you hear anything happening down below?
Old 11-04-2007, 10:54 AM
Bandit-1's Avatar
Bandit-1
Bandit-1 is offline
you would have to figure out witch wire the switch gives power to then use a peice of wire a couple inchs long with some aligator clips on the end of something.
Old 11-09-2007, 10:32 AM
preppypyro's Avatar
preppypyro
Having any luck fixing it?
Old 11-15-2007, 12:12 AM
R031Kona's Avatar
R031Kona
R031Kona is offline
the fix
I just fixed my 91 Ranger transfer case with a 1 /12 work and some elbow grease and 5/16's fuel line. The link https://www.ford-trucks.com/forums/s...d.php?t=123542 read the whole thing first though and it doesn't hurt to google it and read more sources.
Old 11-15-2007, 09:49 AM
preppypyro's Avatar
preppypyro
That is an excellent link r031 thanks for posting it!
Old 11-15-2007, 09:28 PM
R031Kona's Avatar
R031Kona
R031Kona is offline
It really does help to have it on a bench unless you have a helper or three hands IF you take apart the motor itself. The brushes for the armature really are a pain , I did mine in a lube bay and proped it on the transfercase skidplate. Took me 5 try's to get the armature in place :-)
Old 11-18-2007, 10:26 AM
preppypyro's Avatar
preppypyro
Hey 5 trys isnt that bad at all, especially when you succeed in the end.
cbrd1999
1983 - 2012 Ranger & B-Series
05-30-2017 04:50 AM
DeezDay
11-01-2007 11:56 AM
Wild Karrde
03-17-2007 07:57 AM
ldselder32
02-02-2006 01:31 PM
Quick Reply: 4x4 issues
