V8 Flathead parts easy to find?
Old 10-29-2007, 03:12 PM
TheGerman's Avatar
TheGerman
TheGerman is offline
...I`m thinking about bying a German Ford Howling Truck with a Flathead V8 Engine built in 1958 by Ford in Cologne. Is it a problem to find Engine Parts like gaskets, seals, water pump, distributor, generator, starter, carb parts and others?
Thanks
Claus
Old 11-02-2007, 06:59 PM
effie_man's Avatar
effie_man
effie_man is offline
hmm ive only heard of the french ones, not any german ones. Someone with higher learning (know more than me) will post...... i hope
Old 11-26-2007, 06:27 AM
TheGerman's Avatar
TheGerman
...sorry for my bad english, it is a "tow truck" not a "howling truck" - how stupid!
Anyway, what I found out now, there is a german made 239 V8 Engine! The number is G29T. It has an old Block with the distributor in the rear and newer 24 bolt heads with the water outlet in the front corner. I searched at "google" for "G29T" and found some information.
Thanks
Claus
Old 11-26-2007, 09:42 AM
soule46's Avatar
soule46
soule46 is offline
Claus,
I have read that the motor is basically the same as the US built ones. Gaskets and bearings and stuff like that should be interchangable. I read that the German flathead was built until the early '60s.
Just recently someone else asked about a flathead they picked up which also looks German:
https://www.ford-trucks.com/forums/6...engine-id.html
I pointed out in that thread to check out another site:
http://jalopyjournal.com/forum/showthread.php?t=220576
About 1/2 way though that thread a second guy asked about a German motor he picked up. A fellow there posted a picture of his German with US 59AB heads on it. That thread has a link to German stuff (I went there quickly one day but everything is in German and its been 15+ years since I took German).
Here is another good thread over there on the German -- I just did a search for "german flathead" and got a bunch of hits but this one looked interesting -- with contacts who know a little about them :-)
http://jalopyjournal.com/forum/showthread.php?t=12050
Old 11-26-2007, 12:02 PM
TheGerman's Avatar
TheGerman
thank you for your quick help. I already checked the jalopyjournal.com site.
My truck was factory equipped with a V4 2-stroke Diesel engine. You could choose also between a V6 2-stroke and a Flat V8 Engine. These 2-stroke engines were good on gas but had too many problems, so Ford USA decided to quit truck production in germany in 1961.
Claus
Old 12-02-2007, 07:57 AM
TheGerman's Avatar
TheGerman
....put some pictures from my german Tow Truck in the Gallery.
Have a look!
Claus
Old 03-18-2008, 07:36 AM
cpt.phil's Avatar
cpt.phil
cpt.phil is offline
schöner alter truck macht bestimmt viel spaß
Frank
Old 03-19-2008, 04:07 AM
55 f350's Avatar
55 f350
55 f350 is offline
geez that thing is cool !!!! french now german , hmmm i have a lot to learn i see .
Old 03-20-2008, 08:46 PM
Snowking's Avatar
Snowking
Snowking is offline
I can see it now Hitler designed the VW Beatle and the Flathead.
(Yes I know the flathgead came out in 32, it's just a joke)
Old 03-20-2008, 10:12 PM
effie_man's Avatar
effie_man
hitler didnt design the beetle porshe did
Old 03-27-2008, 12:42 AM
jmadsen's Avatar
jmadsen
jmadsen is offline
Nice truck, I really like the steering column, does it have tilt?
Josh
Old 04-06-2008, 08:29 AM
TheGerman's Avatar
TheGerman
No, it has no tilt, no power steering and no brake booster. This truck is only for the tough ones!
What I found out til now is. that many parts are interchangeable.
It has the newer engine style with the water outlets in the front corner of the head, but like te older style, the distributor(Bosch) in the rear.
The transmission is 4-speed manual, and the original radio plays elvis only!!
til soon
Claus
Cobravii
06-04-2017 11:23 PM
Kirk-NJ
03-07-2017 03:09 AM
Luther1956
1947 and Older Ford Trucks
09-24-2016 10:36 PM
Todd15
24
12-28-2015 03:06 PM
10strokin
15
04-18-2006 05:10 PM
Quick Reply: V8 Flathead parts easy to find?
