Ford 300 six in a Jeep CJ??
Old 10-25-2002, 07:58 PM
Randy79's Avatar
Randy79
Randy79 is offline
Has anyone ever tried to put a ford 300 in a jeep CJ? A while back I saw a post listing the dimensions of both and it said the ford engine will bolt right up to the Jeep trans. Can anyone tell me how to find that post? I used search but had no luck!
Old 10-25-2002, 08:46 PM
MustangGT221's Avatar
MustangGT221
MustangGT221 is offline
The six is very long, i'm not sure if it will fit length wise. I believe that the radiator would need to go somewhere else.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Thats it for now, saving for a stang. Check out my Gallery for a look-see.
Justin - One Happy FTE Member
Old 10-26-2002, 12:40 AM
shotgun's Avatar
shotgun
shotgun is offline
A few years back, I read about one in a Four Wheeler magazine. It was set-up for rock crawling and would idle along. You could Email the magazine or scan their website. I don't think it was much different size wise than the jeep 4.0L sixes.
Old 10-26-2002, 03:17 PM
Randy79's Avatar
Randy79
Randy79 is offline
Thanks! Do you remember what issue of fourwheeler? I checked their website but couldn't find anything.
Randy.....
Old 10-27-2002, 07:51 PM
billyb's Avatar
billyb
billyb is offline
Randy, I wrote the reply to that post. the transmission bellhousing on many jeeps has the ford pattern. this is where the tranny bolts to the bellhousing. you can bolt the ford engine with bellhousing attached to some, but not all jeep transmissions. I will either find the post you are looking for or get the info and post it again soon.
Old 10-27-2002, 07:56 PM
billyb's Avatar
billyb
billyb is offline
raandy, the post is in page 6 of this section, under "engine swap". hope this helps
Old 10-27-2002, 07:57 PM
billyb's Avatar
billyb
billyb is offline
hey, there it is!!!!
Old 10-27-2002, 10:34 PM
Randy79's Avatar
Randy79
Randy79 is offline
Thanks billyb!
Old 10-31-2002, 05:07 PM
IBen17's Avatar
IBen17
IBen17 is offline
Hey just put the six in its true home a FORD, of couse if I had a jeep I'd try to change it into a ford too.
Old 10-31-2002, 10:22 PM
Randy79's Avatar
Randy79
Randy79 is offline
>had a jeep I'd try to change it into a ford too. Thanks for the insult -- you've been most un-helpful
Old 11-01-2002, 12:35 AM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
I had an 84 Mazda B-2000 pickup that I lifted and prepped to fit a 300. I had to cut out the floor, firewall, move the radiator to the back, put a Toyota straight axle under it,and build a custom bed for it. I had everything ready to go together, and then blew the engine in my F-250. Unfortunatley, the Mazda died a tragic and early death. But, if I had it to do over again, all ridicule aside, that little rice burner would have gotten that 300, and my Ford would have been scrapped.
Jared
Old 11-01-2002, 01:42 PM
Randy79's Avatar
Randy79
Randy79 is offline
I have a very rusty 79 F-150 with a great running 300 and I have a 78 Jeep CJ, in very good condition except the blown engine. I plan on building one out of the two.
Old 11-01-2002, 01:56 PM
heathdaily's Avatar
heathdaily
heathdaily is offline
Old 01-04-2014, 09:07 PM
Dave 64's Avatar
Dave 64
Dave 64 is offline
Ford 300 into CJ Jeep
Hi,
Read with interest the ten year old topic of Randy wanting info on dropping the bigger 6 cylinder Fords (240/300) into CJ's.
I too have one of each (F250 rotted out but still sound mechanically) also a DJ5D with a crook motor. Preliminary measurements say it's a possibility, have to tool around with the engine mounts, lengthwise with the DJ's funny little extension out past the guards should go close. Probably have to drop the fan off and go electric pusher??
Why would I bother? Long story, back in the good old days, Australian assembled ******/Kaiser/Jeep (before AMC takeover) used 6 cylinder Ford from 144 right up to 250 2V.
As we all get a little older we sometimes regress into adolescence, the more ridiculous the project, the more appealing. A 240 Ford/NP435/ Dana 44 sounds like fun! O.K, bit long, but surely engine/tranny can't be much longer than stock AMC232/727 auto??
Want to keep it simple, so stay 2WD. Postals geared reasonably high, and with no weight of vehicle, should be able to bop along at highway speeds. And yes, I do know and have read comments about taking your life in your hands exceeding 45mph! Hey! Live a little dangerously!
Cheers, Dave 64
Old 01-05-2014, 07:36 AM
waynaferd's Avatar
waynaferd
waynaferd is offline
The 2.3 Pinto motor is a popular swap into a CJ lol...The early ****** anyways!!
My 55 5 has an injected 2.3 from a 96 Ranger....2x the power and almost half the weight of the original F head 4 popper.
But a 300 swap would make any gas powered vehicle better
Quick Reply: Ford 300 six in a Jeep CJ??
