Aerostar Ford Aerostar
Removal of heater hose steel nipple from intake manifold 4L?
Old 10-28-2007, 07:48 AM
96_4wdr's Avatar
96_4wdr
96_4wdr is offline
twisted and turned on mine yesterday. made about 10 revolutions but will not come out.
is this a pressed in steel nipple that feeds out of 4L intake manifold coolant thermostat area?
Old 10-28-2007, 01:53 PM
xlt4wd90's Avatar
xlt4wd90
xlt4wd90 is offline
Gee that sounds almost like the threads on the fitting has stripped. Did you try any pulling action while turning it?
Old 10-31-2007, 05:41 AM
96_4wdr's Avatar
96_4wdr
96_4wdr is offline
no threads. pressed in steel tube into hole in aluminum lower intake manifold into coolant jacket.
had to split out the old tube with chisel and tap hole with 3/8" NPT tap, replaced with 3/8" NPT brass nipple. put in with teflon tape
not a Furd better idea. pressed in steel nipples in coolant connections subject to stress and shaking.
sure made an mess of my nice pretty clean and painted Ford Blue intake manifold after the intake gasket replacement.
suggestion, remove the steel nipple and replace with brass threaded nipple anytime manifold is off for other work. so much easier
my ex-pretty manifold now looks like an industrial jack hammer has been used on that corner
Old 10-31-2007, 10:13 AM
copper_90680's Avatar
copper_90680
copper_90680 is offline
Cliff:
Paint it bright red. There is nothing a good coat of paint won't cover up
Old 11-01-2007, 10:22 AM
bozzzz94's Avatar
bozzzz94
bozzzz94 is offline
Talking
Copper (Tung)
Ahhh so I thought you were a Ford guy
Aero Aero Tauras
REDDDDDDddddddddddddddd????????
Are you have a chevy guy relapse????????
Sorry Charlie----------we bleed BBBBBLLLLLLUUUUUUEEEEEE !!!!!!!!!
Old 11-01-2007, 04:03 PM
krankshaft's Avatar
krankshaft
krankshaft is offline
Were you referring to the steel nipple over the thermostat that the upper radiator hose connects to?
On my 3.0 Aero its just bolted on with two bolts with a gasket between the mating surfaces.
Old 11-01-2007, 04:24 PM
96_4wdr's Avatar
96_4wdr
96_4wdr is offline
heater hose nipple out the top right front of 4L lower intake manifold
Old 11-01-2007, 07:50 PM
krankshaft's Avatar
krankshaft
Oh you mean this guy? (Circled In Red)
One of those other fittings crapped out on me a few years back a hole rusted through the Ford dealer looked at me like I was crazy when I tried to find another one.
None of their diagrams showed it. You can see my brass "Home Depot Special Fix" in This Pic . I used O2 sensor safe High Temp RTV to seal the threads.
The dash temperature sensor plugs into the top and the hose out the bottom tees off from the lower radiator hose.
On a related note here is the original part that the brass fitting replaced just curious if anyone else has this fitting on their 3.0 mines a 96?
Old 11-01-2007, 08:11 PM
96_4wdr's Avatar
96_4wdr
96_4wdr is offline
nothing like that on a 4L. just a straight steel tube pounded 3 inches into a hole in the intake manifold for the heater hose.
it's not listed in ford parts either.
they made millions of these morfidite connections
steel tube pounded into a cast aluminum manifold that is heated and under water pressure, what a dumb engineer cheap trick
Old 11-01-2007, 08:17 PM
copper_90680
Krankshaft:
I did a similar thing with my '93 3.0L.
However, Cliff is right. The 4.0L is a real mess with a press-fit nipple.
Old 11-01-2007, 08:21 PM
Aeroman59's Avatar
Aeroman59
Aeroman59 is offline
They probably sweated it in at about 300* while stress relieving the casting, before final machining?
NPT is a better way to go in any case. Taper pipe threads....they rarely leak once taped in.
Old 11-02-2007, 01:51 AM
krankshaft's Avatar
krankshaft
Just pressed in?
Its suprising what stupid things manufacturers will do to save a buck.
Yet another brilliant Ford innovation probably from the same guy who came up with the headlight switch.
Old 11-02-2007, 10:30 AM
copper_90680
Originally Posted by bozzzz94
Copper (Tung)
Aero Aero Tauras
You have a real addiction problem there Bozzzzzz. 5 Aerostars - one driver?
Oh yes, I used to drive a Jeep with a 2.8L V6 Chevy engine. I got rid of it because I couldn't stand the unfixable oil leak on my driveway
Krankshaft: When I had my intake manifold out of the 4.0L, I thought about replacing that nipple the way Cliff did, but then I chickened out. However, I did replace the nipple on the 3.0L with a brass nipple from Home Depot just like you did.
Old 05-03-2020, 06:58 AM
Beshires1's Avatar
Beshires1
Beshires1 is offline
Have 1999 Ford Ranger 4.0L same strait steel nipple. I loosened clamp and pulled the hose off, except It pulled the entire nipple out of the manifold. The steel that was inserted in the manifold had completely disintegrated.Two unlike metals pressed together like this is a no - no. Off to HomeDepo !
psi3000
12-17-2020 07:04 AM
84espy
06-07-2014 11:05 AM
DIYMechanic
1997 - 2003 F150
12-19-2012 06:14 AM
vista461
Modular V8 (4.6L, 5.4L)
05-23-2012 09:22 AM
gotjeepzj
08-16-2009 08:05 AM
Quick Reply: Removal of heater hose steel nipple from intake manifold 4L?
