1.9L head with micro cracks
Old 10-27-2007, 11:06 PM
Beanscoot's Avatar
Beanscoot
Beanscoot is offline
Hi everyone, I was given a friend's '92 Escort with a 1.9 engine that was leaking coolant into a combustion chamber due to a small channel eroded into the head. The car is in excellent condition otherwise so I had the head milled to clean up the damage, and had a valve grind and jet-clean done.
Now as I put it back together I notice tiny hairline cracks between the valve seats at their closest distance to each other. There weren't any previous problems with the car before the recent leakage, so I wonder if these cracks can be ignored. I'm guessing by the carbon pattern on the cracks that they've been there for a long time.
Old 11-01-2007, 12:17 AM
TigerDan's Avatar
TigerDan
TigerDan is offline
We don't really cover the 1.9 in here as it wasn't available in trucks but I can tell you from personal experience that they are indeed prone to cracking the heads.
I'd take the head back to the machine shop that did the work. That's something that they should have caught. I've heard of many instances where heads were cracked between the valve seats like that but the cracks didn't extend into any coolant passages and didn't cause a problem. However, with aluminum heads, I'd be afraid of the seats coming loose and dropping out...
Old 11-01-2007, 12:33 AM
Beanscoot's Avatar
Beanscoot
Thanks for the advice. I just brought in the bare head with loose valves for a super economy grind so I don't blame the shop. I could have had them pressure test it I suppose but didn't.
I talked to a good mechanic today who assured me that a lot of these type engines have the tiny cracks and usually they would be okay. It's hard to even find a core with no tiny cracks for some motors apparently.
Kind of reminds me of flatheads...
Old 11-23-2007, 08:22 AM
tomw's Avatar
tomw
tomw is offline
The original heads for the Escort were cast in Italy. If that tells you anything. They are known to be VERY easy to crack if they get overheated. Some will have leaking head gaskets between cylinders, and be diagnosed as a cracked head. Many Escorts went to heaven because of the repair cost when the rest of the car was in excellent shape. It was not economic to put $500-800 into a $1500 car... at least a lot of people thought so. So they got car payments of $200-300 for a beater, and paid for the head repair in the next two-three months, and again .. and again until they paid for their 'new' car. In other words, if the rest of the car is on good enough shape, and you are not tired of it, repair is often, if not always, less than 60-72 months of car payments. Your choice. But, you will get over 30 mpg for a long time if you keep it in repair.
tom
Old 11-24-2007, 01:32 PM
Beanscoot's Avatar
Beanscoot
Hi Tom W,
Interesting that those heads were cast in Italy. I repaired the car and it is running fine except for an uneven idle, and the heater being soso in output. The car does have an excellent body and interior though so I'll try to sort out the little problems.
I was told the idle problem was due to a bad temp. sender which should be a cheap fix. You are right about the mileage, this car belonged to a friend who kept a log of mileage and frequently got over 40 miles per (imperial) gallon, mostly highway dri ving. I got hold of a parts car that also had a bad head gasket and therefore was free. It was also in excellent rust free condition but slated for junk because of the leak. Unfortunately I couldn't keep it around due to me living in the city, but I stripped the most useful parts I could think of.
Old 07-12-2009, 03:17 PM
Beanscoot's Avatar
Beanscoot
An update on this car: Well I've been using it as a daily driver for over a year, got it really hot once (the electric radiator fan failed to come on), and there's been no problems.
I am repairing another similar car that had a cracked head. I had to remove a couple at the junkyard before I found a good one, and even it has the micro-cracks between valves. But I'm confident now that it will be fine after a regrind with new exhaust guides.
The major cracks in that bad head were quite obvious and leaked heavily during leak testing, while the micro-cracked head showed no leakage under the same test.
Old 04-07-2010, 08:55 PM
whitefordexplorer's Avatar
whitefordexplorer
whitefordexplorer is offline
my philosophy on the 1.9l.... as soon as it gets hot, throw the head in the nearest trash can. i had a '95 'scort that ran awesome after i replaced the head. i drove from hesperia, CA to vegas, around vegas for two days, and back to banning, CA and only had to fill up once at state-line. and i did 85-90m.p.h. the whole way. i sodl the car back to the lady i bought it from who needed it for her son, and she loaned it to someone and they wrecked it!
Old 04-08-2010, 02:16 PM
Beanscoot's Avatar
Beanscoot
I hope she saved the head!
The car with the micro cracks in its head continues to run fine and shows no sign of coolant leakage. I flushed out the heater core with the garden hose and now I even get heat!
Old 07-23-2011, 02:18 PM
Ricohman's Avatar
Ricohman
Ricohman is offline
This is good to know as I'm doing this repair on my boys car.
The head I pulled at the wrecker is good except for those tiny cracks you speak of.
We are going to put it togther and hope for the best!
Bud Mud
13
07-28-2015 05:40 AM
Bud Mud
22
04-23-2015 05:58 AM
winklershop
12-10-2014 05:04 PM
olfordsnstone
05-23-2013 07:56 PM
jav409
21
03-09-2008 06:33 AM
Quick Reply: 1.9L head with micro cracks
