removing trim around rear window?
Old 10-25-2007, 11:04 AM
canucker's Avatar
canucker
canucker is offline
Can someone please provide some advice how to remove the trim around my rear window.Do you just pop it off somehow?
Old 10-25-2007, 12:47 PM
ATC Crazy's Avatar
ATC Crazy
ATC Crazy is offline
Received 2,728 Likes on 1,326 Posts
If I remember right, there are bolts holding it in from the inside. Hopefully someone will be along shortly to give you better details.
Old 10-25-2007, 01:08 PM
Bobby82490's Avatar
Bobby82490
Bobby82490 is offline
Yeah you have to take the interior apart(headliner, trim pieces, etc.) then there are studs you undo, and it should come off. Im resealing my back window this weekend(4day weekend!) and trading out my trim piece for one that isnt faded.
Old 10-25-2007, 06:11 PM
ncranchero's Avatar
ncranchero
ncranchero is offline
Green is glass bolts, yellow is trim bolts. You have to remove the glass to remove the trim.
Old 10-25-2007, 10:38 PM
Club Wagon's Avatar
Club Wagon
Club Wagon is offline
Thanks for the photo, I'd like to put a sliding rear window in & just saw an ad for 1, but never considered how they were installed. Wouldn't happen to know if the 1 piece rear window installs w/the same 12 screws?
Does the glass come out from the inside? Can I presume you can replace the glass & seal from inside w/o even disturbing the trim?
Old 10-26-2007, 03:13 AM
ncranchero's Avatar
ncranchero
Same bolts for both type glasses. The glass & trim are removed from outside once the nuts are removed. Too bad you're not closer, I'd swap you my slider for your 1 piece glass!
Old 10-26-2007, 05:15 AM
Bobby82490's Avatar
Bobby82490
I took the back window and trim out of my parts truck without taking out the trim, i just pulled it back and unbolted it. But i highly recommend taking out the trim, after i got the window out the trim and headliner looked like crap. It shouldnt take too long to take the trim out(1 hour?). I got to take all my trim out this weekend so i can reseal my window. Also when you get your new window get the window sealant. I just got 15 feet(enough to do the back window) of butyl tape from napa for like $15.
Old 10-26-2007, 05:45 AM
ncranchero's Avatar
ncranchero
I'd get the parts listed at the bottom of this TSB if I were going to the trouble of removing/replacing my back glass.......
TSB # 01-1-11
https://www.ford-trucks.com/tsb/full...hp?tsb=01-1-11
Old 11-04-2007, 11:58 AM
JOE SKI's Avatar
JOE SKI
JOE SKI is offline
ncranchero..thanks for the pics and the link...my '97 f-150 window is leaking also...what a pain getting the vinyl pieces off in order to get at the nuts! I used a long screw driver and bent a fish-hook in it to release the metal tabs, now to repair the cracked plastic frame(junk!)
Old 11-09-2007, 09:43 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is online now
after removing the interior trim, can you take the outer trim off without removing the window? what comes off first, trim or window?
Old 11-09-2007, 10:04 PM
JOE SKI's Avatar
JOE SKI
JOE SKI is offline
__________________
ncranchero shows a picture in the above reply . I didn't remove either since I just put a bandaid on it for now.
Joe Ski
Old 11-09-2007, 10:12 PM
steve(ill)'s Avatar
steve(ill)
i saw the picture and it says the trim comes off last, but i cant find anyone who has removed the window and trim and can confirm that you can not get the trim off first..
Old 11-10-2007, 09:03 AM
02crew's Avatar
02crew
02crew is offline
yes you can steve. there is no lip on the glass or the slider that would not allow you to remove the trim and not the window. peolpe 9 out of 10 times are removing the window to replace or reseal so the trim gets no attention (he he) but like our pal bobby i bet alot of us are going to be pulling the plastic trim and painting them. there is noting worse that a nice looking truck with that stupid faded grey plastisc trim around the window. what do you guys think? gloss back to match the window or body color match?? anyone ever do this yet? pics please
Old 11-10-2007, 09:31 AM
montanafordman's Avatar
montanafordman
montanafordman is offline
does anyone know if there is a good way to refinish or buff the faded window trim? Mine's faded too but I'd rather not go through the trouble of getting it out and painting it or replacing it.
Old 11-10-2007, 09:41 AM
02crew's Avatar
02crew
02crew is offline
i used some turtle wax ice (paste) on mine bit it wasnt too bad to start with. ild try some wd40 on a rag. i dont think anything will be a perminent fix.
Quick Reply: removing trim around rear window?
