gas tank leaking
gas tank leaking
[updated:LAST EDITED ON 11-Dec-02 AT 12:02 PM (EST)]Have a small leak somewhere on the rear tank of the dual tanks. It's on the engine side and I believe its on the top. Very, very small amounts of gas have dripped onto the spare tire, and eventually onto the garage floor. Two questions.
1. Can I fix this myself using some of that gas tank repair stuff that they have at local auto stores by removing the spare tire encasing and searching for the leak on the tank or is this reserved for a professional?
2. What problems would come from leaving it how it is? Is it imperative that it be fixed promptly to avoid any fire, or gasoline problems?
I need all of your expert suggestions on this one. Thanks Much.
gas tank leaking
i had the same problem. drain the tank, then remove it. be careful not to break the sending unit or anyhting. disconnect all hoses. then heat up a rod or something that you can use to heat up, thus to melt soilder onto the tank. DO NOT USE A DIRECT FLAME LIKE A TORCH!!
afterwards use a undercoat to undercoat the gas tank to protect it from stone chips and road salt. this will prolong the life of the tank
gas tank leaking
Sealing it from the outside only ensures that ALL the rust will stay in your fuel system, unless it makes it into the engine. You need to pull the tank, empty it, & dry it with a vacuum cleaner blowing into it for a couple of hours and a 75W drop light under it keeping it warm.
Then use a light & an inspection mirror to assess the damage. If it's minor, use a pour-in gas tank liner or have it brazed. If it's bad, replace the tank.
gas tank leaking
Good information. I'm not as confident working with fuel and gasoline components. Is dropping the tank and sealing the hole something that an "intermediate" skilled do-it-yourselfer can accomplish?
Dropping a gas tank should be easy in theory but are there things that i may damage or have trouble with?
gas tank leaking
i did it when i was 4 or 5 years ago when i knew nothing. my dad guided me through the steps and helped me out, mind you i was like 13 or so. i did it, almost all on my own. needed him to hold the tank up for me so i can reinstall the brakctes as it kept slipping off the jack stands
gas tank leaking
Success. I've isolated the problem and can fix it without dropping the tanks or disconnecting the hoses. Tell me if I'm missing anything here.
Probably a pin hole size leak under the bracket of my rear tank. I have the tank nearly empty. I have 2 thick wood posts to brace the tank securely while I remove the bracket. Once that's off, I'll use the gas tank sealant kit I bought to plug the leak, then clean, sand and apply the fiberglass resin material.
Does this sound easy enough? Do I open the gas cap while doing this and do I need to relieve the fuel system pressure? Thanks for the help.
gas tank leaking
[updated:LAST EDITED ON 14-Dec-02 AT 04:35 PM (EST)]Well, there isn't any "pressure" in the tank save for the fuel that is in there pushing down on the bottom of the tank due to its weight.
I know you don't want to do this, and you don't want to hear this, but I also have a 1993, and I had a similar problem.
Deduction: 1993 (and possibly others') rear metal gas tanks were, and are, crap!
(and they are a time-based deteriorating component, not mileage based... ours went at similar times even though I had 84,500 miles on mine when I changed it out)
My pinhole was near the top - are you planning on covering the whole tank while you're under there?
Do yourself a favor. Do yourself a BIG favor. Change the tank out for a new one. I'm going to predict that you are probably facing seeing many more pinholes within the next year or so.
While doing your changeout, replace the fuel pump, the fuel pump's screen, and the outer, if not the outer and inner, fuel-filler hoses.
Sorry, but I just had to get that out. I don't feel I would be helping you by writing for your plan, or by ignoring what seems obvious (based my the additional knowledge I have of another 1993 pinhole - that isn't to say it should have been obvious to you).
I wish you the best in your endeavor. If you don't address it now, just plan on finding a place, getting the tools, and buying the parts, to do it fully sometime soon.
Best,
Best,
gas tank leaking
Howdy
I have a small leak in my rear tank as well. I just noticed it a couple of days ago. I plan on changing the tank. It must have been leaking for some time. The spare tire was shot from the gas leaking on to it.
So if you had your tire under there, you should have a close look at it.
Tony
Tony
gas tank leaking
Either way you go fix or replacing the tank.
Most people prefer to:
1. Remove the six bed bolts. (spray a few days prior with PB Blaster) Also spray metal strap bolts on fuel tank.
2. Unhook the fuel filler tubes.
3. Unhook tailight wires.
4. Remove tailgate to make bed lighter.
5. Have buddy help lift off bed for easy access to both tanks.
The fuel tank is now much easier to remove and reenstall. Unhook the sender wires prior to dropping the tank, as they aren't long enough with the tank on the ground.
Chris
Chris
Eallend7
06-10-2013 10:31 PM
Truck problems2
20
04-11-2012 07:08 PM
cantedvalveFord
10-07-2007 10:19 AM
