Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
95 lightning 5.8 a/c, power steering eliminator
Old 10-16-2007, 08:26 PM
bliss1's Avatar
bliss1
bliss1 is offline
im going to post this here sense you guys will have the most knowledge. ive got a 95 5.8 out of the lightning and im putting it in a 65 f100. heres my ?. idont need the smog pump, a/c compressor, or power sttering pump. i would like to eliminate all this but all i find is eliminators for the 5.0. will the 5.0 alt brackets and pullies fit the 5.8 so i can use the 5.0 a/c, power steering eliminator. any help or suggestion would be great.
Old 10-16-2007, 10:57 PM
Blurry94's Avatar
Blurry94
Blurry94 is offline
The 5.0 smog pump eliminator will work. I've seen some A/C and P/S eliminators, but I'm not sure if they're 5.0 pieces as well.
Old 10-17-2007, 10:16 AM
Silver Streak's Avatar
Silver Streak
Silver Streak is offline
I recently did a 5.0 to 5.8 swap in a 92 F-150 and all the brackets lined up. Ford put two sets of holes in all of them so they would fit either deck height. They should work, and if they don't they should give you a good place to start building from.
Old 10-17-2007, 07:55 PM
bliss1's Avatar
bliss1
bliss1 is offline
so i should use the 95 5.0 brackets and eliminators. the problem i have is if i use the 5.0 eliminator wich will fit i will have 2 tensioners because the alt braket on the 95 has the tensoiner boult into it. so ill start looking for the 5.0 parts wich sounds like they willl work.
Anthonynoble
04-18-2015 07:58 PM
95gearhead
03-10-2009 10:17 PM
bliss1
Engine Swaps
08-29-2008 11:22 PM
mike mac
08-26-2007 06:52 AM
Quick Reply: 95 lightning 5.8 a/c, power steering eliminator
