Merc Heads
Old 10-16-2007, 07:37 PM
Kazoo's Avatar
Kazoo
Kazoo is offline
Merc Heads
Any difference in Mercury Heads and Ford Heads??
Spoke to a gentleman today that has a 53 Merc, well, one head got ruined at the machine shop and we both got to wondering if a Ford head could be used on the Merc block.
Old 10-16-2007, 08:24 PM
flat6inline's Avatar
flat6inline
flat6inline is offline
Smile 49-53 Mercury Heads.
I have a machined fresh pair of 1950 Mercury Heads , that I just got back from Daytona Auto Machine. These are the cast heads that say Mercury on them.
I had them machined out to compare to the Aluminum OFFY 400.'s . This heads will take the high lift 400 cams and the larger Chev. type valves for your flathead motor. These heads are copper coated inside with a black powder coat on the outside. These have not been put on a motor since I got them back. If you want a stock look on your flattie but want High Performance inside, then these are what you need. I am only selling these becauce I sold the Mercury I had. I have $ 438.00 in these head. I will take a rock bottom price of 300.00 for them. You would not be disappointed. You can use these on a stock motor as well. Let me know if you need them. Thank you Dave.
memorylane60@charter.net. They are still in the box . shipping would be around 35.00 . I live in Michigan These heads were Magnfluxed and trued.
These are one of a kind heads.
Old 10-16-2007, 11:10 PM
mtflat's Avatar
mtflat
mtflat is offline
To answer your question, yes, Ford and Mercury heads will interchange. The Ford heads have slightly compression ratio depending on which year they are. 1952/53 EAB heads are the ones that are desired. 8RT, 8BA or other variations are lower compression.
Merc 8CM heads are similar to 8RT as far as compression ratio goes. Any other Ford head would improve things a bit.
Old 10-17-2007, 09:01 PM
Kazoo's Avatar
Kazoo
Kazoo is offline
Thanks MTFlat, discussed this with the gentleman today and your help lifted his spirits quite a bit.
probepower
27
05-01-2014 08:03 AM
d-day
15
04-12-2014 05:16 PM
Bowman85merc
180
04-22-2012 09:37 PM
e-tek
41
04-25-2010 10:50 PM
cdwyer
07-14-2001 04:30 PM
Quick Reply: Merc Heads
