Propane
Old 09-26-2007, 09:27 PM
MSF350's Avatar
MSF350
MSF350 is offline
Propane
My dad called tonight and wanted to know if I had heard about the Propane injection systems.
I told him I would post on here and find out about them good, bad, void warrenty, how much gain in hp & fuel mileage?
Thanks in advance for any help.
Old 09-27-2007, 01:52 PM
Phydeaux88's Avatar
Phydeaux88
Phydeaux88 is offline
Propane injection, when properly tuned, can produce as much as 80RWHP increase. It may increase fuel economy but any savings are offset by the cost of propane.
There are two basic types: Vapor (gas) phase systems and Liquid phase systems.
Liquid phase systems are most common. Liquid propane is taken from the tank to a vaporization chamber where it turns into propane gas the gas is metered into the intake air thru a jet or series of jets. In a multi (usually 3 or 4) jet system the amount of propane being delivered is controlled by opening and closing jets. The result is incremental (step stair) increases in propane as need increases. Single jet systems provide a constant flow of propane no matter what the need. Both of these systems produce periods of excess propane and other periods of insufficient propane.
Vapor phase systems draw propane gas from the storage tank. A constantly variable regulator delivers the propane in amounts proportional to the need at that moment.
As need increases the propane flow is ramped up as need decreases the flow ramped down, its like turning on a faucet you can adjust the amount of water to suit your requirement.
Vapor phase systems are safer because there is no way droplets of liquid can enter your intake air flow. Liquid phase systems can allow liquid propane droplets to enter the air flow should certain critical components fail. Liquid propane in your engine will ruin the engine and your day.
My system is the Powershot 2000 a vapor phase system. I use it when I tow my fifthwheel trailer in hilly terain. It helps a lot.
Old 09-27-2007, 09:01 PM
MSF350's Avatar
MSF350
MSF350 is offline
Thanks for the information. I would like to have it when pulling my horse trailer. But does adding this void your warranty?
Old 09-28-2007, 12:06 PM
F250_'s Avatar
F250_
F250_ is offline
I have also seen a post where one propane user said that he got reduced propane pricing on tank refills since he was using it as vehicle fuel. The price difference he quoted was pretty big, which would certainly justify the expenditure in the long haul if he is right about the discount. Otherwise, what I've heard is that propane is economically justifiable as long as the price for proane is equal to or less than the price of diesel (roughly).
Here's the other thing. You've got to have gauges to protect the engine. It can get awfully hot awfully fast if you're not aware of what's happening, and then you're faced with damaged parts that aren't cheap to replace.
Old 10-02-2007, 10:57 AM
Phydeaux88's Avatar
Phydeaux88
It will definetly void your warranty
Fireslayer
08-29-2013 12:19 PM
SwOkcOffRoader
01-15-2008 11:53 AM
FordTrucksKickGM
Alternative Fuels, Hybrids & Mileage
09-06-2007 09:21 PM
fishindave11
04-22-2007 10:34 AM
kiksomepoo
12-21-2002 10:35 AM
Quick Reply: Propane
