Serial Number Decoding
Old 09-11-2007, 11:51 AM
cj5968's Avatar
cj5968
cj5968 is offline
Smile Serial Number Decoding
I'm trying to get the Serial Number decoded on my Econoline pickup. I believe it's a '61 - '62, but really not sure. Any help would be appreciated!
Old 09-11-2007, 12:20 PM
cj5968's Avatar
cj5968
cj5968 is offline
Serial (Warranty) Number
Oh, if anyone can help, the Warranty # off the Door Jamb is E10TH387289. Other information that I can read includes: WB 090, Color A, Model E103, Body 87A, Trans A, Axle 01. Thanks in advance to anyone who can assist me!
Old 09-11-2007, 03:54 PM
merlynr's Avatar
merlynr
merlynr is offline
E10TH E10 econoline T = eng code my book shows J or U
H = assembly plant ; Lorain, OH.
axle= 3.5:1
trans = A 3 sp
87A = pickup
color = black
wb = 90"
sorry, I didn't quote. other digits are serial #. The E10THxxxxxx is your vin #
Old 09-12-2007, 09:46 PM
66gpw's Avatar
66gpw
66gpw is offline
The warrenty tag from my books say.
E10 for pick up.
T for 170 6 cyl
H is the Lorain plant,
The rest of the numbers say the truck is a 1963. The number run in consectutive order since manufacturing started in 61. So that looks about mid to late 63.
Old 09-22-2007, 08:46 AM
rossbeal's Avatar
rossbeal
rossbeal is offline
Decode numbers
Can anyone decipher - E16AHB34688
Old 09-22-2007, 09:29 AM
66gpw's Avatar
66gpw
66gpw is offline
Merlynyr the T code says you have a 170 eng. J code is a 240 engine that were installed in 65 and newer. The S code is for a 200 6 cyl also installed in 65 and newer.
Rossbeal I will try and decode for you.
My books do not show a E16 for 61to67 Econolines.
Also the same for the A. which is susose to be the engine size.
The H is the lorain assembly plant.
The B I have no idea.
The other numbers are suspose to be the sequence the van was manufactured in.
Are these numbers from a newer Econoline than 61-67's. ?
For they are not in my books and do not look like any I ever seen here before?
Old 09-22-2007, 09:54 AM
rossbeal's Avatar
rossbeal
rossbeal is offline
These numbers are from a wreck found out in the woods and we are trying to positively indentify it for use of parts. Could this be a Falcon wagon?
Old 09-22-2007, 09:55 AM
rossbeal's Avatar
rossbeal
rossbeal is offline
This is definitly a 61-67 econoline body style.
Old 09-22-2007, 12:59 PM
66gpw's Avatar
66gpw
66gpw is offline
It could be. The E15 is the last number my books show. That is up til 65. If newer it may be an added number. Also on the tag with the warrenty number there should be a model number. That can help identify what style of van it is.
Check out Econosarus. There is a Jim Bare on that site from Arkansas that can help you he has lots of info on serial numbers.
northerndave
03-24-2017 04:40 PM
Leathers65
01-08-2017 11:00 AM
Pacecar1986
01-02-2017 05:56 PM
Opus 97
06-01-2016 05:06 PM
matts_auto
06-12-2014 11:21 PM
Quick Reply: Serial Number Decoding
