Dyno results F150 (CAI, catback, tuner)
This is appears to be a good honest article. Exactly what I'd expect out of these three mods. Low end torque increased nicely:
http://http://www.supermotors.net/ve.../16162/54602-2
With the truck still stock, we made a dyno run so we could gauge the performance of the new parts. The truck made 247 horsepower and 282 ft-lbs of torque in stock trim. The Edge Evolution has three power levels, trans only, towing, and performance. On the towing setting, torque jumped to 287 ft-lbs but more remarkably, peak torque moved from 4100 rpm to 3600 rpm and torque below 3000 rpm increased by almost 10 ft-lbs. We set the Evolution to performance and the truck belted out 261 horsepower, a gain of 14 peak hp while still producing 285 ft-lbs of torque and a much smoother power curve. Results like that make engine guys like us sit up and take notice. Check out our photos to see how this might just be the easiest 14 hp you will ever get.
Originally Posted by mrpositraction
Read the whole article, he only quoted the last paragraph, that was with all parts on from my understanding. A lot of money for 14hp.
Originally Posted by FTE Ken
I've written tunes for the 5.4 for NA 87 octane that yielded far more than that with just the tuner. I know of one tuner picking up 20+ HP on the dyno with 87 octane. Something sounds wacked in this application...
on
Its not because they were for a specific application and datalogged. Those numbers are for my regular tunes. I can do even better with datalogging and application specific tuning. That's why I said something sounds whacked.... I've seen many "canned" tunes do better on the 5.4 3v than 14 HP - including Edge.
I did the full top end on my Mustang including full exhaust. With a custom tune completed on the dyno after all these mods were done and after driving it around for a while on the stock computer, I netted 10 rwhp and 17 rwtorque. I know I'm not comparing apples to apples here, and I'm not trying to be a smartass, but I always take what I read on the net with a grain of salt.
BTW, I may have only netted that much hp and torque with the tune on the Mustang, but the drivability is much better, amongst other things, so it was money well spent.
on
Tuning the 5.4 3v V8 is more than just strapping it on a dyno, advancing the timing and getting the A/F right -- especially with the F150. There are huge untapped potential with its tuning due to the things Ford does to make mileage numbers for the EPA.
Not to be a smartass, but if that's the best you could do with an intake, full exhaust and a custom dyno tune then you also need to replace the person tuning the car. Tuning the 5.4 3v V8 is more than just strapping it on a dyno, advancing the timing and getting the A/F right.
http://http://www.kennedysdynotune.com/
on
There are examples of dyno graphs all over the Internet doing much better with just a tune. Even the 4.6 does better than that article showed:
http://www.fordmuscle.com/archives/2006/04/F150/index.php
Besides, the 5.4 3v is not a 1995 Mustang GT. There is a lot of HP left on the table even with 87 octane -- a lot. Its programmed very conservatively from the factory. I don't do mail order (just the locals), but if you give Mike Troyer a call the guy will knock your socks off with his F150 tuning. I've just seen too many examples of good 5.4 results to think that 14HP peak with that combination is good.
As I noted: something is wacked. My guess its the intake, the conditions were bad (dyno correction still doesn't quite compensate for poor ambient conditions) or the truck was heat soaked. The 5.4 3v because of the positioning of the MAF, is very prone to A/F problems with aftermarket intakes. Many people claim gains with the butt-dyno but in fact some intakes for the 5.4 result in less HP and a bottom end torque loss. Oh, the noise makes people think they are doing better, but they aren't. This is why the article should have dyno'd each piece as it was added. We could have seen the results, and it would be more apparent where the problem is.
RacinNdrummin
52
12-09-2016 11:24 AM
RacinNdrummin
69
07-07-2016 07:42 PM
FORDF250HDXLT
51
06-10-2011 05:35 PM
Silver Streak
32
08-12-2003 06:02 PM
DeenHylton
05-02-2001 10:29 AM
