Set Ignition Timing 1996 4.9l F-150
Old 09-02-2007, 10:01 AM
joe.mcfadden's Avatar
joe.mcfadden
joe.mcfadden is offline
Hello All
Today I Want To Use My Timing Light To Set My Ignition Timing On My 1996 F-150 4.9l. Do I Have To Disconnect Any Thing? Like In The Old Days When You Somtimes Had To Disconnect The Vacuum Advance. My Truck Has No Vacuume Advance So Im Wodering If There Is An Electronic Connector To Pull Prior To Changing The Timing. The Remainder Of Task I Know. Thanks
Old 09-02-2007, 10:15 AM
quicklook2's Avatar
quicklook2
quicklook2 is offline
the spout is a plug you need to remove.
it is right around the distributer and is usually grey.
10 degrees btdc is the setting you should set to with spout out.
welcome to fte.
Old 09-02-2007, 12:01 PM
joe.mcfadden
Spout As In Connector? I See Two Diferent Connectors Small Type One Comes Off The Coil, The Other Goes To The Block. Im Still At Least 100 Degrees Off Using The #1 Spark Plug Wire For The Pickup. Thanks For Getting Me Started.
Old 09-02-2007, 01:35 PM
DrBones[LCD]'s Avatar
DrBones[LCD]
DrBones[LCD] is offline
Check for a plug w/a grey connector at the ICM (Ignition Control Module), which might be fender mounted (driver's side) on your truck.
Old 09-02-2007, 03:07 PM
quicklook2's Avatar
quicklook2
this is a good time to buy a manual.
it will help for things like this and other harder problems.
Old 09-02-2007, 03:46 PM
Wynn96's Avatar
Wynn96
Wynn96 is offline
Wait. I have a 96 and the spout is NOT near the distributer. It drove me nuts. It is by the driver side hood hinge, and it has two pink wires going into it. You have to pull the gray plug from the end of it and don't lose it.
Old 09-02-2007, 04:18 PM
quicklook2's Avatar
quicklook2
different engines have them in different places.
77bronco87
02-08-2015 10:32 AM
1986F150six
04-29-2014 02:51 PM
1986F150six
02-25-2013 01:21 PM
joe.mcfadden
01-16-2012 09:44 PM
Quick Reply: Set Ignition Timing 1996 4.9l F-150
