Ontario Chapter Join Chapter>, Leader: loudfords
New here
Old 08-29-2007, 08:44 AM
lmnr0026's Avatar
lmnr0026
lmnr0026 is offline
New here
Hi fellow Ontarians. I've recent picked up an '89 e350 at auction to convert to a camper. More details in the general introductory thread. Nice to see some 'local' representation on the board.
I'm looking to swap out the RA gears for something a little taller, where would y'all recommend I look for parts? I live in Toronto, the vehicle is near Barrie. I checked with Cooksville auto (or Cookstown?) who have done well for me in the past but they only sell the whole rear assembly. I just need the pod.
Back to reading through all the great posts here, and getting generally edumacated on all things ford-truck.
Cheers,
Ron.
Old 08-30-2007, 07:14 AM
fp_5's Avatar
fp_5
fp_5 is offline
Welcome to the Ontario chapter....yours to discover
The Barrie automotive flea market is comming up, you might luck out there. Also post what your looking for on our chapter foresale/want ads thread.
Good luck
Frank
Old 09-01-2007, 06:16 PM
Blackstock's Avatar
Blackstock
Blackstock is offline
Former Vendor
If it is any help to you, we have some good pricing on aftermarket and Ford crown and pionions. Example for a '89 Full size Van 8.8" rear, a Richmond 3:73, 4:10 or 4:56 set are $195 and if you need a complete install kit $110 COMPLETE INSTALL KIT INCLUDES - PINION SHIMS, CARRIER SHIMS, CRUSH SLEEVE, PINION SEAL, PINION NUT, RING GEAR BOLTS, COVER GASKET, CARRIER BEARINGS AND GEAR MARKING COMPOUND. 2) THIS IS SAME AS RAYTEC INSTALL KIT PLUS CARRIER BEARING & MARKING.Our supplier has it all in stock next day delivery 5 days a week if ordered by 4PM.
Old 09-07-2007, 10:25 AM
lmnr0026's Avatar
lmnr0026
lmnr0026 is offline
Thanks Jim I will probably be getting ahold of you when I get that far into this project. this is an '98 e350.
Steeple923
General Automotive Discussion
01-20-2013 06:01 PM
muskeg_mapper
17
03-03-2010 01:46 PM
48fordjeffie
01-16-2007 08:47 PM
Jigsaw
Ontario Chapter
02-20-2004 10:38 PM
Corry
03-21-2000 05:51 PM
Quick Reply: New here
