Got My Arse Kicked By 07 F-350 Stocker @ Pulls
Got My **** Kicked By 07 F-350 Stocker @ Pulls
Hi Folks, Pulled Saturday Nite In Yerington Nevada. Have Pulled Much Further In The Past. I've Got A 99 F-250 W/ 7.3, 3:73 Gears, 4r100 Trans, 315/75r16 Tires, Super Tuner @ 105 H.p. Performance Setting, 4" Exhaust, 6637 Mod, Arb Air Locker In Frt Diff. Stock 07 F-350 Kicked My A@#. I Pulled Only 197 Feet, Usualy Pulling 225-230 Ft, He Pulled 246 Ft With Stock Size Tires No Upgrades Other Than An After Market Air Filter Or So He Says. Any Ideas As To Why
if your pulling on a transfer sled, momentum is everything I own a 97 250 zf 4.10 and a 03 250 zf 6spd 6.0 with 3.73 s both trucks are chipped and exhausted and on the transfer sled there is no comparison at 8000lbs the 6.0 will flat out out run the 7.3 because itll spin 4100 rpm wheelspeed is everything. But when I'm hauling logs theres nothing like the off idle grunt of a 7.3.
Can I ask what gears did he have in the rear. Did you power out or spin out. Waht did he do when he pulled. power out or spin out. My guess with your older truck some 4:10 or higher gears for that. Dont forget tire kinds an pressure make big diffences in pulling also.
One more question what can configuration are you both running. Reg,super or crew.
Can I ask what gears did he have in the rear. Did you power out or spin out. Waht did he do when he pulled. power out or spin out. My guess with your older truck some 4:10 or higher gears for that would be better. Dont forget tire kinds an pressure make big diffences in pulling also.
One more question what cab configuration are you both running. Reg,super or crew.
Originally Posted by strokin'_tatsch
i don't think he had a stock truck. if you could pull almost 250 ft with a stock 6.0 then everybody would buy them and mod them with a tuner, exhaust, and intake and probably make a full pull. that guy was probably lyin' to ya
I pulled 265 with my 6.0 when it was stock with almost bald goodyears on it....
HI FOLKS, BEEN ALOT OF SNOW HERE SO I'VE BEEN PLOWING ALL WEEKEND.
HIS TRUCK IS CREW CAB W/ 6.4 3:73 I BELIEVE. HE OWNS THE DEALERSHIP SO IT,S HARD TO SAY WHAT HE MAY HAVE DONE. BUT I TALKED TO A COUPLE OF HIS MECHANICS & THEY WERE THE ONE'S THAT TOLD ME HE ONLY HAD A K&N AIR FILTER ON IT & NO OTHER UPGRADES. I THINK HIS TRANS HAS ALOT TO DO WITH IT.
WHEN I PULL I HAVE TO BE IN 1st OR DRIVE WHEN I START THE PULL, IF I PUT IT IN 2nd THE TRANS WONT GO INTO 1st GEAR & I GET NO START AT ALL.
I HAD MY GOODYEAR MTR TIRES IN THE FRONT DOWN TO ABOUT 15# OF AIR, REAR TIRES @ 60#
I WAS TOLD THATS THE WAY TO RUN THE TIRES BECAUSE OF THE WEIGHT ON THE REAR WHEELS. MAYBE COULD LOWER THE PRESSURE ON REARS NEXT TIME TO 30-35,
HOPING FOR SOME ADVISE THAT WILL HELP PARDS! GONNA BE A WHILE FOR TRANS UPGRADES ECT FOR A WHILE BOUGHT A NEW HARLEY LAST WEEKEND. I OWE I OWE SO OF TO WORK I GO GO GO. LUKE I HEAR YOUR TRUCK IS THE DODGE KILLER. MAYBE NEXT YEAR FOR ME TO START PLAYING AROUND LIKE YOU.
