1990 Ranger 4.0 V6 torque specs
Old 08-19-2007, 03:31 PM
4x4powerstroke's Avatar
4x4powerstroke
4x4powerstroke is offline
What are the torque specs for heads and rocker arm for 1990 Ranger 4.0 V-6?
Old 08-20-2007, 01:10 AM
rocker_topper's Avatar
rocker_topper
rocker_topper is offline
the head bolts are 44 lbs im not sure about the rocker arms sorry if i can find it i will post it
Old 08-20-2007, 08:43 AM
TigerDan's Avatar
TigerDan
TigerDan is offline
44 ft/lbs is the torque for the first step. After setting them to that in the correct sequence, set them to 59 ft/lbs. The third step requires that they be tightened an additional 80-85º, which is slightly less than 1/4 turn. I mark the head of each bolt so that I have a reference point.
Also, you are using new head bolts, aren't you? These bolts are torque-to-yield and can only be used once as they stretch when torqued.
Rocker shaft supports are 46-52 ft/lbs.
Old 08-20-2007, 12:13 PM
4x4powerstroke
Thumbs up Thank-you
thanks very much for your fast response to my ? bout torque specs
Old 08-20-2007, 08:56 PM
TigerDan's Avatar
TigerDan
TigerDan is offline
I didn't think it was all that fast, but you're certainly welcome...!
Also, my Chilton's manual talks about installing the intake manifold at the same time as the heads and torquing them alternately. I've never heard of doing that on anything else, you'd just about need two torque wrenches (if using the click type) in order to keep from having to reset the torque wrench for every bolt.
tow2sno
15
09-27-2014 12:12 AM
Ranger2003
1983 - 2012 Ranger & B-Series
05-19-2012 08:25 PM
HogginNboggin9
10-05-2009 07:16 AM
fuzzyzero
03-08-2004 12:03 PM
swampdog2002
12-28-2003 07:57 PM
Quick Reply: 1990 Ranger 4.0 V6 torque specs
