How many have problems with Climate Controls?
Seriously, we have taken our 07 expedition to our reputable dealership at least 6 times and they can't find the problem! Here's what going on; Climate control button are pretty straight forward. I've read the owners manual where it says that if you use the "auto" button, the system will automatically determine fan speed, airflow location, a/c on or off, therefore, when the vehicle reaches a certain temperature, it will SHUT OFF. Kind of like a thermostat in your own home. This is what Ford techs have told me and this is what I interpret from the manual. My problem is that when setting the a/c to "manual", instead of the "auto" feature, the a/c shuts off completely without warning. This is after driving it for a couple of hours. This normally happens during the day, although a few times it has happened during the night. Ford thinks I have it set to "auto" and is the reason it keeps shutting off. What so frustrating is they haven't found anything because when it goes to Ford, they NEVER find anything when they take it for a test drive. Is anyone else experiencing this, please help!
i had a similar experience one time. I had been driving approx. 3 hrs. and pulled up to a red light, air conditioner completely shut off, but the controls still showed it being on. Tried turning a/c automatic climate on then off, nothing. The blower wasnt even blowing, but the rear a/c worked fine. Arrived at house, turned truck off, let sit for a few minutes, turned truck back on and it has worked flawlessly since.
Yes, Ford also told me that if I plug the cell charger in one of the outlets, it supposedly causes the a/c to shut off. I have NOT used the cell phone charger since the issued was first brought up to the dealership. This problem with the a/c shutting off continues and I feel Ford in now making excuses. It is also getting to be very annoying, especially when it shuts down in 100 degree weather! Anyone else with this problem?
I agree, it only does it on long trips or when driving for over two hours. The thing is, it does'nt always do it. I am hoping that the damn unit gives out all together to they can replace it or something. But with the luck I've been having, the a/c unit starts up again after shutting off the car for 10 minutes or more. The only thing Ford found is they said the fan shroud was not aligned correctly and was causing the car to overheat a little bit. They said this might have been part of the reason the a/c unit shuts off because of a special sensor that warns the computer when the car overheats, therefore, shutting down the a/c unit momentarily. Anyway, they fixed this issue on my 5th visit to the dealership, but the problem continues.
To be honest with you, I never really paid attention to the temperature gauge, I mean, you figure the truck is brand new. Why even look? However, I am closely paying attention to all gauges. The temperature gauge reads normal so far, it is slightly below the mid-point. I don't know what else to do, but turn on the a/c unit every time we drive the truck and hope it gives out completely.
I have 7500 miles on my two-month old limited and it's done it twice. Just shuts off completely for about one to two seconds, then right back on. Both times were at stop signs.
I have had a similar problem with my 05 F250, as have many other people. But in the pickup's case it's more like something in the electrical system that shuts down the whole dash. In those cases turning off the truck for a minute or two and then restarting fixes it.
It's obviously a Ford problem. I'm not aware of any TSB's on it (yet).
