Umo
Umo
So.
is there a way i can use UMO, or motor oil as 2 cycle oil?
I hate buying the stuff, its so expensive. And i have motor oil and UMO setting around. I have a weed wacker that needs to be used.
I threw the UMO with sea foam in it into the chainsaw bar oil thing. Worked pretty good. It was still pretty honey colored. =-) I'm sure it kept the chain well cleaned hahaha.
UMO, ran it. Then I plugged it, then I ended up replacing injectors. Unless your going to find some way to get all of the miniscule heavy metals from scratching and marring all of your surfaces, I would use it to heat your house in the winter. Not a fan, but others are. Im one of few with 516k plus on my engine and ive screwed it up with everything except bio.
motor-man
12-21-2009 12:11 AM
TJC1989
18
05-28-2008 12:03 AM
BigRed350
Bio-diesel, Propane & Alternative Diesel Engine Fuels
08-14-2006 11:25 PM
