My brake light wont go off?!
Old 07-23-2007, 09:11 PM
boggerted's Avatar
boggerted
boggerted is offline
the red brake light on my 84 F250 just wont shut off. It used to work fine until one of my brake lines busted and i replaced all the front brake components, new calipers, pads, lines, sliders. I bled the lines and the pedal doesnt feel mushy. Is there something i need to reset? Wheres the sensor for this light? Also, aving the parking brake on or off makes no diffrence in the light.
Old 07-23-2007, 10:47 PM
Franklin2's Avatar
Franklin2
Franklin2 is online now
Received 1,678 Likes on 1,356 Posts
There is a wire going to the proportioning valve. If you take the wire off, the light will probably go off.
What happens is the proportioning valve has the front brake system and the rear brake system both in the one housing. The only thing seperating the two systems is a plunger. If the pressure in both the front and the rear is equal, then the plunger stays centered, and the light stays off. Since you busted a front line, the pressure dropped in the front and stayed high in the rear, so the rear pressure pushed the plunger forward and turned the light on.
After you go it fixed, the plunger did not re-center itself. So what you can try to do is open a rear bleeder and hit the brakes hard. This may push the plunger back to center and turn the light off.
Old 07-24-2007, 06:06 PM
boggerted's Avatar
boggerted
I see, i might try to recenter it if the bleeders arent siezed up, but the light is just annoying, so i might pull the plug.
Old 07-24-2007, 10:47 PM
kc5gxl's Avatar
kc5gxl
kc5gxl is offline
To reset the light is a two person operation. You will need to break the line going to the rear brakes loose at either the master cylinder or at the porportioning valve. Turn the key on and have someone gently push down the brake pedal. Have him yell out when the light goes off. Have him hold the brake pedal at that point and tighten the line back up. Let up on the pedal and then step on it again. The light should stay off. It might take a time or two to get the feel of it, but that is a pretty good way to do it.
Hope that helps,
Dan Harriman 84 F150 lwb
Orange, Texas
Old 07-25-2007, 07:03 AM
boggerted's Avatar
boggerted
I see sounds like a plan. Thatll be a good project. Thanks for all the help.
Old 07-25-2007, 07:13 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
If this is the switch that controls the low brake fluid warning light on the dash, it has a tendency to leak brake fluid. What happens is the plastic switch, which screws into the brass proportioning valve, develops minute cracks around the threads. This allows just enough brake fluid to seep past, activating the switch. The light on the dash comes on, and stays on.
D5AZ-2B264-A .. Low Brake Fluid Warning Light Switch
Old 07-26-2007, 07:42 AM
boggerted's Avatar
boggerted
I did the operation today and it fixed my problem. No more annoying red light! Thanks for all the help.
Old 02-24-2008, 06:27 PM
hugger94's Avatar
hugger94
hugger94 is offline
Sounds like the same problem with my 84 F250. I was very concerned that it might be a "cold weather issue" because it started staying on right after trying to get my 6.9L started the other morning at 17 degrees. Guess I will check out bleeding the brakes to center the plunger.
hugger94
Shadowrider123
03-03-2015 12:55 PM
highboyhouston
10-22-2014 10:44 PM
liberty2701
13
08-12-2011 07:33 AM
goose213
1978 - 1996 Big Bronco
11-22-2004 03:12 AM
mikemike
Electrical Systems/Wiring
10-24-2001 06:52 PM
Quick Reply: My brake light wont go off?!
