Southern Region Alabama, Arkansas, Florida, Georgia, Kentucky, Lousiana, Mississippi, North Carolina, South Carolina, Tennessee and Virginia.
Oil Pressure on 1994 F150
Old 07-22-2007, 10:50 AM
busby's Avatar
busby
busby is offline
HI all and good day. I have a question on my 1994 for f150 with a 302 engine. The oil pressure. After it warms up the oil pressure is ok but as I drive the truck the oil pressure drops down to zero and when I slow down to idel it comes back to normal. The engine never rattled. What would cause this? Also can the oil pump be changed without pulling the motor out?
Old 09-07-2010, 09:31 PM
kennethrasnake's Avatar
kennethrasnake
kennethrasnake is offline
it can be changed without pulling the engine but it sounds like your sump is stopped up to me. And changing it without pulling the engine is a pain, you have to take out the motor mounts and lift the engine and trans as far up as possible and drop the oil pan and you will barley be able to fit you hand in there to change it but it can be done I have done it.
Old 12-30-2020, 05:12 PM
mcdavidson's Avatar
mcdavidson
mcdavidson is offline
Busby, I know this is a long time ago, but did you ever get this resolved (Same issue, same year, same motor)
captain1997
12-14-2014 04:55 PM
jxer00
05-06-2005 03:39 PM
canda250
02-02-2004 09:20 AM
binkley
42
08-06-2002 02:43 PM
Quick Reply: Oil Pressure on 1994 F150
