Best spark plugs and other tune-up parts for a `92 460?
Old 08-15-2002, 10:34 PM
Idaho's Avatar
Idaho
Idaho is offline
[updated:LAST EDITED ON 15-Aug-02 AT 11:38 PM (EST)]I'm going to do a tune-up on my truck in the next couple of days and was wondering what components are the best. I usually use NAPA for distributor caps and such. Since I've been driving a Nissan for the last couple years, I've been using NGK spark plugs. What plugs work best in a FI big-block? I used to use split fires in my muscle cars with some success, but haven't had good results with them in modern 4-bangers and V6s. Ditto with platinums.
My truck has only 42,000 miles on it, what components should I be replacing?
Also, any relatively cheap way to make the ignition burn a little hotter, like adding an MSD Blaster coil?
Old 08-16-2002, 12:27 AM
TorqueKing's Avatar
TorqueKing
TorqueKing is offline
I've used them all, and I have found that Motorcraft perform as well as any of them do. The only thing you can do to get more performance out of your spark plugs is to gap them over, say .050".
Old 08-17-2002, 08:08 AM
georgedavila's Avatar
georgedavila
georgedavila is offline
cogden
02-25-2017 10:38 PM
Kevinwil
09-12-2016 07:45 PM
dnkensinger
08-30-2015 04:30 PM
brandonnys
Modular V8 (4.6L, 5.4L)
08-17-2015 09:29 AM
JPMallory
07-18-2015 02:17 PM
Quick Reply: Best spark plugs and other tune-up parts for a `92 460?
