fuel filter wrench size
Old 06-26-2007, 08:06 AM
akula22's Avatar
akula22
akula22 is offline
Question fuel filter wrench size
hey guys i wanted to change my fuel filters today and need the size for the hfcm cap is it 31,32,33 mm i cant seem to get the tech folder to open the fuel filter changing procedure area, thanks for any help.
Old 06-26-2007, 08:44 AM
earp's Avatar
earp
earp is offline
HFCM fuel filter takes a 36mm or a 1 3/8" socket. I use a 36mm socket.
Hope this helps.
Daryl
2004 F250 4x4 CC KR
Old 06-26-2007, 09:05 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
yup--36mm and I got mine at sears for like 6 bucks--cheap.
Old 06-26-2007, 10:01 AM
origcharger's Avatar
origcharger
origcharger is offline
Or you can get the nifty close clearance, aluminum, 3/8" drive socket from Lisle Tool specifically designed for filter changes on 6.0 Powerstrokegs.
Old 06-26-2007, 10:15 AM
Mustangbru8's Avatar
Mustangbru8
Mustangbru8 is offline
the fuel filter cap is the same size as the oil filter cap?
Old 06-26-2007, 10:27 AM
Beerstalker's Avatar
Beerstalker
Beerstalker is offline
I don't think they are exactly the same, but they are close enough that everyone uses the same socket. Somebody correct me if I'm wrong.
While we are on the subject though, what is the correct torque value for the filter caps?
Old 06-26-2007, 10:43 AM
origcharger
The Lisle socket is advertised as fitting both sizes.
Old 06-26-2007, 11:04 AM
Mustangbru8
oil filter cap= 18 lbs./ft
frame mounted fuel filter= 19 lbs./ft
secondary fuel filter (under hood)= 8 lbs./ft
Old 06-26-2007, 11:24 AM
Beachbumcook's Avatar
Beachbumcook
Beachbumcook is offline
Got Diesel?
Just screw until seated all the way. I have heard many state that the plastic caps will hit their "torque value" before they are seated all the way.
Just screw down and tighten until flush and it will not turn any more. No need to use a "breaker bar" or "lean into it"... just make it tight and visually look to see that it seated all the way down.
Old 06-26-2007, 01:44 PM
npccpartsman
Yes--on my 04 anyway.
Old 06-26-2007, 01:45 PM
OZX1's Avatar
OZX1
OZX1 is offline
Same here. $6.80 at Sears...
brother steve
6.7L Power Stroke Diesel
15
10-29-2015 02:24 PM
Jonesy0027
12-11-2013 10:47 AM
macguy
11-30-2012 07:01 AM
fordtruck661
10-22-2011 08:44 PM
Blind45
09-09-2008 12:29 PM
Quick Reply: fuel filter wrench size
