81 Ford
81 Ford
I have a 1981 Ford F150 Trailer Edition I was wondering what kind of rear do I have in it the rear end has all the bolts towrds the front of the truck and I was wondering why my vin would say I have a 351W when my engine compartment says its a 5.8LM/6.6L and How can you tell the diff between the 351W the 351M and the 6.6L
351M/400 = 8 valve cover bolts. 6 valve cover bolts = 351W
My 6th digit is an H, but anywhere else on the vin there is not another H or S, but also mine is an 80, so i can get a socket to the bottom 2 bolts, but i cant not get a socket rench in their, so i have an 9 inch right, i can only get a 9 16 rench in their, thanks guys, but my 6th is an H. So if you can clear me up.
Taylor
Taylor
youve got a 9 inch if the bolts are pointing toward the front, a 351m is a big block even though it doesnt look it, the 351 windsor and 351 cleveland are small blocks, and if you have 8 valve cover bolts its a big block (351m or bigger) if it has 6 valve cover bolts its a small block (351w or 351c or smaller), how you tell if its a 351m or 400 i dunno, i thought that 351m meant 351 modified to a 400 because every sticker on the valve cover ive seen for a 351m says 351m/400
Originally Posted by jdgreen72
f_balla you are right about the 351m/400 bein' a 400 cid motor, but not all forward bolt rears are 9", ford also made a 8.8" that looks exactly like the 9, but the lowest 2 bolts are not accessible with a socket.
The ones that are hard to tell the difference if they are not side by side is the 8 inch rear and the 9 inch. Those are the older style rears that look the same, and you can use the socket test. They also made an oddball 9 inch in some of the cars that won't interchange. But the 8 inch and the oddball 9 inch were never used in trucks.
zoobiedoo
08-10-2009 01:37 PM
OneSweet81
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
13
08-08-2009 09:15 AM
dpc
06-15-2005 01:15 PM
81rangerF150
19
09-04-2004 09:07 PM
81rangerF150
07-29-2004 01:55 PM
