New Hampshire Chapter Join Chapter Leader: 7283-F250
Reliable Ford Dealer
Old 06-18-2007, 03:47 PM
VQ2Fast4U's Avatar
VQ2Fast4U
VQ2Fast4U is offline
I need to find a reliable Ford dealer to tear into my motor, when I changed my oil last I tapped on the bottom of the pan with a wrench and heard a peice of metal rattling around. I bought the truck used from MJ Sullivan in New London and was "given" an aftermarket warranty. On paper the warranty looks great, but once you call and speak with them its a differnt story, the warranty company that is. So I need a ford dealer who knows diesels and will do the work under warranty. Thanks, Adam
Old 06-18-2007, 06:49 PM
dzlpwr's Avatar
dzlpwr
dzlpwr is offline
Where abouts you located?I always use Gabrielli Trucks in Milford.Thats all they do there is diesels.If the warrenty thing dont work out let me know I got a guy that works there that will do whatever you like(on the side of course) fairly cheap compared to the dealer.
Old 06-18-2007, 09:02 PM
VQ2Fast4U's Avatar
VQ2Fast4U
I live in S.Windsor, but driving to a good place is not a problem. The only reason I want to get it done under warranty is because theres only a $100 deductable, and the motor needs to be pulled to remove the oil pan on a PSD which costs $$$. I dont mind doing the work myself, I have the equipment just trying to save some time, and money. Im going to call Gabrielli Trucks in the morning thanks.
Old 07-25-2007, 08:35 PM
96f150's Avatar
96f150
96f150 is offline
It might be the tappet from the lift pump that dropped down into the pan. That would mean they had to replace your lift(fuel) pump at one point or another. Just in case you didn't know, your lift pump is right on top of your motor.When you remove it you have to be sure the tappet comes out with the pump, otherwise it will fall into the block.
Rich
egregg57
08-15-2011 11:05 AM
sully13
46
11-20-2007 06:19 PM
Ghostgunn
Garage & Workshop
03-17-2005 09:50 PM
Quick Reply: Reliable Ford Dealer
