Member By County
Member By County
I finally started working on the Chapter Directory Image Map for the website, and could use your help to save some time.
In a nutshell, I will be using the WA map with the counties. As you hover over each county, a list of members will appear. Eventually, I would like to make linkable drop downs so you can click on a name and PM or view profile listed at FTE.
It will save me some research time if each member can List their name and county.
1. Placermike Clallam
No need to post here anymore...I took the info I got, and researched the rest.
The map looks pretty good. As you hover over a county, You will get the county name, and a list of members...When you click on the county, you will be directed to the county page.
It may appear that I live in many counties..LOL That is because I used a mouseover and repeated it.
Check it out http://www.clubfte.com/users/washing...directory.html
Originally Posted by RexB
Very nice, you're going to get the nickname "Nuclear Knuckles" if you keep typing all that code.
