JP fuel
Old 05-31-2007, 12:27 PM
blksiryder's Avatar
blksiryder
blksiryder is offline
JP fuel
well i have been searching around and didn't find much on the use of JP fuels. ie jp4 jp5 jp8. i know that jp4 is bad. but what about jp5 and 8 if i were to add some type of addative to make it less dry? (2 stroke oil 100:1) just wanted to know i have a almost endless stock of jp 8 and 5
Old 05-31-2007, 02:53 PM
Phydeaux88's Avatar
Phydeaux88
Phydeaux88 is offline
What makes you think JP4 is bad. It is probably the closest to #2.
Try this link and follow other links on the page you will get lots of info.
http://en.wikipedia.org/wiki/Jet_fuel
If you mix it with BD you should have no problems.
Jet fuels are essentially refined kerosene and kerosene is refined diesel.
Some of the newer Jet fuels, like JP5 and JP8 have some additives to affect performance and possibly some lubricity enhancers but shouldnt really prevent it from working in a diesel engine.
The biggest problem in Jet Fuel is the total lack of sulpher lousy lubricity.
Old 05-31-2007, 06:45 PM
cookie88's Avatar
cookie88
cookie88 is offline
JP fuel with two stroke oil or even transmission fluid, which is a high detergent 10wt oil, should run fine. The fuel trucks on base run the same JP-8 going into the birds...so I know it'll burn....just need to lubricate it to keep from scoring your expensive injectors.
sticktime
6.4L Power Stroke Diesel
30
01-15-2019 06:00 PM
jp petracco
03-16-2015 06:33 PM
brokeisnojoke
21
01-05-2012 09:03 PM
kupaa
36
10-10-2008 11:27 PM
Mustangfreak
05-19-2005 07:30 AM
Quick Reply: JP fuel
