1990 Bronco Interior Parts
Does anyone know if there is a year spread difference in interior parts for a 1990 Bronco? I need a new glove box door, lock set for the center console box, and the large piece of headliner trim where the cap and the interior join together. The dealer no longer stocks these parts and I would like to know if parts from a 1991 or 1992 are the same or did Ford radically change the interiors those years.
>years.
AS you probably know, Ford had the style like yours from 1987-1991. The 92-96 style was a completely different inside. The glove box, and console lock is the same as the doors. You may be able to buy aftermarket locks from a autoparts store, but I would try to get the locks from ford. I had to replace the ignition switch in my 93, and I had to go back to Ford, because, the key opens the doors and the ignition. Hope this gives some luck.
Evan A.K.A. PastMaster
1993 F-150 302/E40d XLT
1989 F-150 302/Aod 4x4 XLT Lariat
>years.
vfelix702
15
12-28-2010 01:09 PM
