Introducing Better High Flow Catalytic Converters
The term high flow has long been abused by various catalytic converter manufacturers. Most of the "High Flow" converters are inferior to the OEM part they are replacing. Most if any benefits are the result of the larger pipe size and free flowing mufflers.
Bear River Converters carries several lines of premium quality catalytic converters that are designed to meet todays stric emissions standards and help you get more power out of your ride. Most of the converters marketed as high flow by competitive companies are suitable for use in cars and light SUVs, but are much smaller than original equipment on trucks and larger vehicles.
Our wide body converters are comparable in physical size to original equipment, and are available to fit pipe sizes up to 3". The larger body gives you a better deeper tone, helps quite the engine, and lets it breath better. This means more power, better fuel economy, and longer engine life. It also helps the catalyst function more efficiently and last longer. Our converters are constructed constructed completely out of 409 stainless steel, unlike competitors products which are made with aluminum. This results in better corrosion resistance.
Please take a look at our website to see some of the selection we offer. We have been in the exhaust business for 10 years, and we specialize in catalytic converters. Feel free to send us an email through the contact form on our website or use the direct fit parts request to find a direct bolt on replacement.
