shifter stuck in park
Old 05-15-2007, 06:12 PM
f150v602's Avatar
f150v602
f150v602 is offline
well ive read about it in other threads and it happend to me. My console shifter on my 04 fx4 wont go out of park unless i hit the white release button next to the shifter and im gettin pretty tired of doing that. Has anybody out there found a hard fix for this problem?? Or does anybody know the spacific troubleshooting steps to use when trying to find out whats wrong?? I would apreciate all advice. Thanks
Old 05-15-2007, 06:17 PM
Beast12's Avatar
Beast12
Beast12 is offline
I could be wrong but doesn't it mean one of your brake lights are burnt out? Maybe check them (including the high mount 3rd brake light).
-Matt
Old 05-15-2007, 06:54 PM
Cuisinart's Avatar
Cuisinart
Cuisinart is offline
It is definitely tied into the/a brake pedal switch somehow, and it's probalby the same one that actuates your tail lights.
Old 05-15-2007, 07:01 PM
f150v602's Avatar
f150v602
f150v602 is offline
Is that the most commom problem? The brake light switch? Thats what i have gatherd from other threads. I plan on checking my brake lights but its storming outside right now so i will have to wait. Hey Cuisinart, what kink of lift tire/rim size combo is on your truck?? I love it!! ( sorry to get off topic)
Old 05-15-2007, 09:07 PM
73f350sc's Avatar
73f350sc
73f350sc is offline
Like Matt said....Check your tail lights...if one is burnt out the park shift interlock switch wont let it shift....other than that...is it still under warranty? If so have them take a look.
-Chris
Old 05-16-2007, 01:23 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
I will be a p'off person if I get a call from the wife and she says she is stuck out in town because the truck won't shift out of park...especially if it's something stupid like a brakelight burnt out.
is this true?
Old 05-16-2007, 01:27 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
Fist make sure the brake lights work if so the shift interloc is bad. its about a 60.00 part from the dealer.
Old 05-16-2007, 03:55 AM
f150v602's Avatar
f150v602
f150v602 is offline
[QUOTE=tylus]I will be a p'off person if I get a call from the wife and she says she is stuck out in town because the truck won't shift out of park...especially if it's something stupid like a brakelight burnt out.[QUOTE=tylus] I couldnt agree with you more.
Old 05-16-2007, 03:59 AM
ford390gashog
There is a procedure to check the shiftinterlock, i am trying to locate it for you right now.
Old 05-16-2007, 04:13 AM
f150v602's Avatar
f150v602
f150v602 is offline
Man that would be great, i hope you can find it
Old 05-16-2007, 06:37 AM
HomerWinzlow's Avatar
HomerWinzlow
HomerWinzlow is offline
Actually the brake lights and shift lock are on separate circuits going thru the brake switch. There are 6 pins to the boo switch and two power circuits. The brake lights are illuminated thru pin 2 on the light green wire and powered thru pin 1 light green and red from fuse 2.02 at the interior fuse box.
The shift lock actuator is activated thru pin 6 pink and light green and powered by pin 5 light blue and pink thru fuse 2.14.
So at pin 1 at the floor shifter module you should get 12 volts with the brakes applied and key on and you should also have 12 volts to pin 2 with key on from fuse 2.15. Pin 6 provides ground.
BTW when I say 12v I am implying battery voltage, what ever that might be for your battery condition and loads with key on.
Old 05-16-2007, 08:40 AM
Cuisinart's Avatar
Cuisinart
I have a procomp 6" suspension lift on 18x10R18 rims with 35x12.5" tires (nitto terra-grapplers)
and thanks
Old 05-16-2007, 03:21 PM
f150v602's Avatar
f150v602
f150v602 is offline
well all checks passed. brake lights worked and the brakelight switch works and im getting power to the brake park interlock solinoid. guess that means the solinoid is bad. man i hate that and the part at the dealer cost 220.00. for the mean time i wedged somthing in there to keep the button pressed so i dont have to take off that panel everytime i want to sift out of park. but to make things worse, the spring that is under the shift handle that keeps the shift rod down, well i broke it. dumb *** me . Thanks everybody for your input. It all helped in my quest to solve this stupid problem.
Old 06-08-2007, 10:14 PM
charmedbridge's Avatar
charmedbridge
charmedbridge is offline
Shifter stuck in park.
We had the same problem with our 97 f-150! All it was were a few fuses in the dash! I'm glad I looked here before tearing the darn thing apart!!! It took a total of an hour to figure and fix the problem. Ford Forum Rules!
Old 06-09-2007, 11:00 AM
benningstspeed1.0's Avatar
benningstspeed1.0
benningstspeed1.0 is offline
7l3z-7e096-a List $136.62
Quick Reply: shifter stuck in park
