1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
keyless entry stopped working
Old 05-15-2007, 11:48 AM
99fatboy's Avatar
99fatboy
99fatboy is offline
Hello all, on my 99 DRW my keyless entry just stopped working. Either remote doesn't respond. I replaced battery on one of the units just to eliminate the obvious. I checked a few fuses and they are ok. I am planning a more thorough search one evening but any ideas what I should be looking for? Don't know if this is related or not but my left turn signal blinks very fast all of the sudden as well.
-Rick
Old 05-15-2007, 03:35 PM
ccerniglia's Avatar
ccerniglia
ccerniglia is offline
Rick,
Take your key put it in the ignition and turn it to off, then turn it from run to off 8 times ending with the key on, the locks should cycle once. if they do not, then you module is dead. If they do cycle, press one button on a single remote and they should cycle once more and then turn the key back and pull it out.hopfully if should work by then.
Old 05-16-2007, 01:33 PM
99fatboy's Avatar
99fatboy
99fatboy is offline
can't explain it but I got under the dash and unplugged the unit and pulled each fuse and plugged everything back in and it started working again. Weird. Thanks for the info anyhow ccerniglia. I'll keep it handy for the future.
Haveyoudrivn1lately?
26
09-22-2021 05:31 AM
twigsV10
13
09-28-2015 10:33 AM
bubba_3711
17
04-26-2015 08:55 PM
fx4king2011
2009 - 2014 F150
08-30-2014 09:21 AM
AndeyHall
07-29-2013 04:57 PM
Quick Reply: keyless entry stopped working
