Making your own BD mix
Old 05-14-2007, 01:18 PM
billygoat's Avatar
billygoat
billygoat is offline
Is it possible to make your own BD? For example, can I make B50 by using 50% diesel and 50% veggie oil I purchase in bulk from Sam's Club? Would I need to filter the oil first or could I just pour it in the tank?
TIA
Craig
02 X 7.3L PSD
Old 05-14-2007, 01:22 PM
monsterbaby's Avatar
monsterbaby
monsterbaby is offline
No you have to convert the oil to biodiesel first before you can mix it and make b50. most say you can't mix straight vo with #2 cause it won't stay mixed.
Old 05-15-2007, 12:42 PM
Phydeaux88's Avatar
Phydeaux88
Phydeaux88 is offline
B50 is not made by mixing #2 diesel and Vegetable oil.
It is made by mixing #2 diesel and Biodiesel.
Burning unheated VO is not recommended, it will eventually destroy your engine. If you want to burn VO convert your truck and do it right.
If you dont want to convert your truck stick with Biodiesel, it isn't that hard to make.
There are those that swear you can blend VO with any number of fuels and burn it unheated, some of them hang out here; however, science does not support them and the risks are great, you could lose your motor.
Old 05-15-2007, 01:12 PM
billygoat's Avatar
billygoat
Thanks to all for your replies....
I guess it's not as easy as missing regular gasoline (ie. 87 octane with 91 octane). I just assumed that the diesel engine would not know the difference between VO and Diesel if you poured both in the tank. (I'm not a chemist, biologist, etc)
Thanks for clearing it up! I'll stick to the Biodiesel as soon as a station opens up near me.
Greywolf
06-17-2014 06:25 PM
OnTheTrail
1999 to 2016 Super Duty
13
06-17-2008 09:34 PM
Dsl Lover
13
02-04-2007 11:12 AM
kawika
12-28-2004 09:55 PM
HeavyAssault
Car/truck Buying Advice
06-01-2004 08:31 AM
Quick Reply: Making your own BD mix
