Roller cam Distributor gear?
Old 05-03-2007, 09:49 PM
nickmobile67's Avatar
nickmobile67
nickmobile67 is offline
What dist. gear is needed for the roller cam 302 and how can you tell them apart? How long will an incorrect gear live? Will there be visible wear on the gear if it's wrong, or only on the cam gear?
Old 05-03-2007, 10:27 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
You need a steel gear, the cast one will eat up and fill the engine with shavings. The steel gear has a smooth surface and the cast gear will look a little rough, like a head or block casting.
Old 05-04-2007, 08:50 AM
nickmobile67
Ok, I think I have thw wrong gear. I have another distributor with a bronze gear, can I toss that in? I wanted to take the car to NC tomorrow. It needs to be reliable.
Old 05-04-2007, 12:02 PM
ken75ranger's Avatar
ken75ranger
ken75ranger is offline
Bronze will work with either cast or steel cams but it's not usually the best choice. The bronze gears tend to wear out quickly. You could definately use it for now and replace the gear for a steel one when you get some free time.
Old 05-04-2007, 12:07 PM
baddad457's Avatar
baddad457
baddad457 is offline
I ran a cast geared distributor for a few minutes in a 331 on an engine stand, it maybe had 5 minutes run time, and it had noticeable wear. This was a fresh reman distributor. Before swapping gears, you might want to just buy the correct distributor instead. New reman distributors run about $55 from Advance Auto Parts, the steel Ford Racing gear is only $10 or so less.
Old 05-04-2007, 12:32 PM
nickmobile67
Well this cast gear seemed to hold up ok over the last 5 years and 6k, but it was a little shiney on the teeth. I threw in the distributor with the bronze gear, and put the other in the back.
I can check the gear for wear when I get down there, but it's gotta last the 700 mile trip there too.
Old 05-04-2007, 02:14 PM
Blurry94's Avatar
Blurry94
Blurry94 is offline
I don't see where a broonze piece would work better being that it's softer than cast.
Old 05-04-2007, 03:06 PM
kotzy's Avatar
kotzy
kotzy is offline
The load from the distributor itself is not the problem it is the load on the gear from the oil pump.
Old 05-06-2007, 06:49 AM
lisagoud's Avatar
lisagoud
lisagoud is offline
I've got one last question I've been dying to ask, any problem using a steel gear on a non-roller cam?
Old 05-06-2007, 08:21 AM
baddad457's Avatar
baddad457
Yea the same problem you run into with a cast gear on a steel roller cam. The softer metal gets worn by the harder.
Old 05-06-2007, 08:50 AM
lisagoud's Avatar
lisagoud
lisagoud is offline
Thank-you...steel with roller....cast with non-roller
wtroger
05-20-2019 01:24 PM
69issofine
02-03-2015 11:05 PM
fordzilla
11-15-2006 02:24 PM
Trail Rider II
08-07-2003 11:54 PM
perryphilip
06-06-2003 07:20 PM
Quick Reply: Roller cam Distributor gear?
