*** IMPORTANT Message For Ontario Chapter Members! ***
on
1 Post
The Webmaster has run an automated routine in the last week for Chapter Memberships. Some of you had your membership removed. Not to worry, there is a reason behind it.
First, check out the following link and see if you are listed or not. If you are, then you don't need to do anything.
https://www.ford-trucks.com/forums/3...r-members.html
If you are not listed (but used to be) here is the reason: the program that was run checked for your location that is listed in your profile. Since this is the Ontario Chapter it was looking for Ontario. If you did not fill that in then it deleted you from the membership list.
All you need to do is click USER CP at the top left then click Edit Profile. In the fourth box down (on the right) put ON. Then scroll down to the Additional Information section. You might as well put your location in there as well. That's the location that shows up in your posts. Then Save Changes.
Now, that is done click Chapter Memberships on the left hand side. Then on the right scroll wayyyyy down to the bottom to the Ontario Chapter. Click JOIN CHAPTER. Send in your request and I will add you to the list again.
If ANYONE has any questions about what to do then DO NOT hesitate to ask.
-Matt
-Matt
on
1 Post
Just an important step to let people know. After you add ON to your profile you MUST do the following:
Just adding ON does not add you to the list.
-Matt
-Matt
on
1 Post
