B100 and "The Hutch Mod"
I brew my own Bio and just got a 55 gallon replacement tank form AeroTank for my 02 F250 7.3. I want to do the "Hutch mod" when I change the tanks over, but I am concerned about the compression union fittings that I see most folks are using. They look to be made out of copper or brass. I have read that copper and brass are not compatible with biodiesel. What are your thoughts? Anyone running B100 with a Hutch mod?
Thanks
Thanks
While it is true that copper and brass are not compatable with biodiesel, the real question is "how not compatable".
Long term contact can cause a problem but since the fuel is only in contact for a few seconds most of the time, it should be fine.
This is true for a copper fitting or two.. Not for an entire copper line.
I would not worry about it..
ITP sells a pickup tube that you can attach an aluminum fitting to. The connection point would be outside the cap of the tank. I'm going to do just that when I get the chance to re-do my fuel system. Right now I am running B99 pretty much exclusively so maybe I'm a lab rat for finding out how long that brass fitting I have submerged will last.
You can also modify the hutch mod and harpoon mod with just normal fuel line. I think your thinking of the harpoon mod in the tank and the hutch mod is the replacement of the fittings outside the fuel tank. Removing the ability for air to be sucked into that fitting. Most the guys here dont have the 7.3 newer except for Fat and a few others. No your not the lab rat. I think the Phydeaux or Fab will be better suited to tell what the reaction is. I think it just has to do with the amount of oxygen in the fuel, but it wouldnt be any more then oxy in the air we breath right?
Chipworkz
22
04-15-2012 02:59 PM
2danglong
04-28-2009 08:33 PM
Lushman
06-27-2006 06:56 PM
