Burning Used Motor Oil
While I don't run used oil in my 7.3, I do run a 25% mixture in my 6-71 Detroit.(the old 6-71 really doesn't like this new fuel) When I have clean hydraulic fluid, I will run as much as 50% mixture of it. I have run this engine for several years at these rates with no adverse affects.
I have a friend who is running an older Mecedes 4cylinder non turbo on 75% used oil and 25% gasoline. He has run this car for over 2 years like this, and has no problems with it. He does have a mixing system which filters down to 2 microns.
Coincidence that I just posted a similiar question here:
http://biodiesel.infopop.cc/eve/forums/a/tpc/f/9751014871/m/5101055591
In reading the above link from Fabmandelux, it seems that some have run UMO with next to no filtering. In my query on the other forum I am talking about processing it just as I do my WVO, which many call overkill in the steps I take. This would include a mistwash for acids, settling, heating to seperate water and filtering down to 1 micron nominal.
I have a friend they run 50/50 on the farm.
I think they only run 25/75 in the trucks if they do though.
If you are going to mix in motoroil, Filter it good. There are metal particles in the oil, injectors probablywont like them much.
I would Mix it slow. start out with a small mixture if your serious with it. only 10/90.
To much and they get a little cranky. Anotehr guy on here tried it though, he said that his ford took a dump. =*( poor truck.
Thnx.
what kinda look is that?! haha
catbird7
Bio-diesel, Propane & Alternative Diesel Engine Fuels
79
01-12-2008 10:31 PM
jamie m
03-03-2003 12:34 AM
