How to change the PCV valve..
Old 04-15-2007, 11:55 AM
DJdemon6696's Avatar
DJdemon6696
DJdemon6696 is offline
i know how to change it but how to get to it ? its behind the intake and hard to get to ... any tips?
i know for shure its clogged.. and need to be replaced
Old 04-15-2007, 02:10 PM
jroehl's Avatar
jroehl
jroehl is offline
It's a pretty tight fit on the 351, but there's a little give to the grommet, so pull it out until it touches the intake, then pull/push it toward the back of the engine while still pulling it out, and it should pop out. Sometimes it helps to pull the vacuum hose first. Bottom line is, you just have to force it a bit.
Jason
Old 04-15-2007, 05:26 PM
Red Raider 4x4's Avatar
Red Raider 4x4
Red Raider 4x4 is offline
I just changed mine on my 302, all I have back there is a hose, just get your hand under there, pull back and forth a bit, make sure your truck is cold, tricky part is just getting off the hose and back on. Its not bad though.
Old 04-15-2007, 06:29 PM
DJdemon6696
ok thanks that will be tomorow's project since i have no shool this week
and Red Raider4x4 still no succes with the truck ? does it still want to die?
jamhh
1997 - 2003 F150
10-10-2013 04:39 PM
02 Super Duty Guy
1999 to 2016 Super Duty
08-06-2013 06:39 AM
F 250 6 liter
03-06-2013 06:39 PM
jbodin18
07-17-2011 10:28 AM
one5150fisher
2004 - 2008 F150
19
02-08-2007 07:08 PM
Quick Reply: How to change the PCV valve..
