Question
Question
Fabman,
I obtained a vacuum pump and a tank to recover to. I plan on pulling the vacuum from my modified appleseed through the condenser mounted to the reactor than into the recovery tank. I have two more questions.
What temp should the bio be at when I pull the vacuum?
What would happen if I left the glycerol in the reactor with the bio (instead of setteling and seperating the two into different containers). Can you also recover the methanol from both at the same time. Either before they settle and seperate or after they settle and seperate then pull the vacuum?
Originally Posted by Gun-Driver
Fabman,
When I was using vacuum I had the temp at 100 deg F.
CheaperJeeper
Bio-diesel, Propane & Alternative Diesel Engine Fuels
01-29-2009 03:53 PM
Rushmore X
11-28-2008 04:59 PM
ckal704
07-17-2008 01:36 AM
AndysFords
02-02-2007 11:28 AM
fabmandelux
37
04-04-2006 06:52 PM
