Code P0299 Turbo Underboost
Have A Code P0299 Turbo Underboost. No Lights On, Just Some Issues Like Excessive Lag, Stumbles Out Of A Corner. Wondering If Someone Can Tell Me If This Is A Sensor Issue Or If The Turbo Has To Be Replaced. It's Still Under Warranty I Just Hate The Thot Of Removing The A/m Goodies,and Even Worse.....being With Out My S/d
You would need to load the stock file from the SCT because they may want to 'flash' the truck while it's in. I wouldn't worry about the exhaust at all. The water/meth injection though, they could blame turbo issues on that whether valid or not.
My main concern would be confirming the service department where you take your truck has 6.0 Certified Technicians. If they don't then find one that does or you'll definitely regret it.
Do you have the stock intake on the truck?
[QUOTE=BowTieHatr]well i can tell you it is a sensor issue or that the turbo needs replacing, and probably still be wrong. cetain pids will need to be watched on a test drive to pinpoint the issue. it could even be a ypipe issue or a boost leak. good luck getting it fixed.[/QUOTE
I DID CLEAR THE KAM AND RAN THE TURBO THRU THE VGT RELEARNING SYSTEM, AND IT DID SEEM TO CHANGE THE WAY THE TRUCK RAN FOR A SHORT TIME. DONT KNOW IF THAT MIGHT HELP NARROW IT DOWN?
Originally Posted by CanadaGuy
Why not?? I find it quite amusing when I'm losing my shirt doing a warranty headgasket job caused by mods...
Originally Posted by Beerstalker
I was kind of wondering how he was losing money by doing the work and getting paid by Ford. I can see how Ford is losing money but not the service department.
TIREDLR I had this same code come up on my truck, I took off the edge progammer and placed everything to stock and reset, drove truck for a few miles, no check engine light yet, But I did notice the Egr test on my OBD11 tool was always on. Any updates on what fixed yours? Any info would be grateful.
