Competition Diesel racing, sleds, dynos, power tuning and max performance.
water vs coolant in 6.0
Old 03-22-2007, 09:54 PM
cabinetmaker00's Avatar
cabinetmaker00
cabinetmaker00 is offline
Question water vs coolant in 6.0
Would it run colder with water or should I stick with coolant ,
I know the reason my coolant is boiling ,the egr cooler,but until I put on a egr delete up pipe my engine is going to run hot .
So i'm thinking about just running water with water wetter ,but if the stock coolant is still good after boiling I'll stay with it.
Old 03-22-2007, 10:34 PM
blackhat620's Avatar
blackhat620
blackhat620 is offline
You need to switch to Evans waterless coolant, much better than standard antifreeze and also better than water.
www.evanscooling.com/main1.htm
Hope this helps
Old 03-23-2007, 06:59 AM
SR_Crewchief's Avatar
SR_Crewchief
SR_Crewchief is offline
Water by itself has a lower boiling point than a 50/50 water/coolant. You'll have more overheating problems as well as other issues with straight water.
EconolineFan
22
06-25-2019 04:18 PM
bevisbeck2
08-22-2016 09:18 AM
rybike13
6.4L Power Stroke Diesel
02-08-2016 08:23 AM
mfp4073
1983 - 2012 Ranger & B-Series
03-07-2013 07:59 PM
brickie
07-29-2012 07:43 AM
Quick Reply: water vs coolant in 6.0
