Iowa Chapter Join Chapter, Leader:
Tire Upgrade
Old 03-20-2007, 05:56 PM
federal123's Avatar
federal123
federal123 is offline
Tire Upgrade
Hello Ford Forum,
I have a 2001 Stock Ford Excursion XLT 4x4 / V-10 engine. I want to install 4 Michelin 285/75/R16 Tires on the stock rims that came with the excursion. What's on the excursion now is Pirelli Scorpions A/T. Will the Michelin Tires fit on there without any rubbing or modifying the stock way it is now. Thank's alot for any info. that you can give me. Newbie in Iowa.<O</O
<O
Last edited by FTE Trigger; 04-05-2007 at 08:54 PM. Reason: Removed MS Office coding.
Old 03-20-2007, 06:20 PM
69 and 85's Avatar
69 and 85
69 and 85 is offline
I would try the 97-03 forum. Not sure how many Iowa guys have your truck. It's pretty quiet in here too... might get a faster reponse there.
Good luck... the bigger the better as long as they don't rub (much)!
Old 03-20-2007, 06:45 PM
federal123's Avatar
federal123
Thank's 91 I will give that a try.
Old 03-26-2007, 04:09 PM
CBSuperduty's Avatar
CBSuperduty
CBSuperduty is offline
You should be OK. I just put 285's on my F350.
Old 04-04-2007, 07:45 PM
farmb0y's Avatar
farmb0y
farmb0y is offline
No problem, ran 285's before and now have 295's and still don't rub.
Texas 6.0
02-19-2012 09:14 PM
Texas 6.0
1999 to 2016 Super Duty
02-14-2012 07:04 PM
federal123
03-22-2007 06:51 PM
federal123
03-22-2007 01:21 PM
teg2_nv
10-05-2006 08:59 PM
Quick Reply: Tire Upgrade
