Looking to add Bluetooth to 07 Expy - How to disassemble the dash?
Has anyone installed a bluetooth car kit to their 07 Expy? What type did you install and how hard was the install? I have no idea how to even get into the radio either, so any help with that would be great, especially if you know of a good online manual.
Thanks!
Thanks!
I installed a Parrot CK3100 LCD.
Thanks!
Thanks!
The install will take about an hour if you are comfortable splicing wires. The center console comes apart really quick.
Also I have a NAV unit not the radio. But I am sure the time is the same.
Randy B
No it does not.
Randy B,
When the phone rings, does the radio say phone? I have seen this displayed on another site but not sure if it is real or not.
I am not aware of a Ford compatibility possibility since they do not offer a phone solution for integration. All they offer is a Blue tooth solution called Mobilease which is based on a non-display Nokia model much like the new Parrot without the LCD head.
The only integration you will get from either of these kits are the speakers will function for hearing the current caller and the radio will mute. Otherwise that's it.
For the price of Mobilease, I went with Parrot and have a much better car kit now then Ford offers.
Randy B
Here is the phot I saw of the radio saying phone, but I guess that is for advertising only. It came from a site that sells the integration harnesses for the Parrot kits. I think I am going to go this route instead of cutting and splicing. Then if I need to remove it, it is simple uplug and plug the factory connectors back together.
07, 2007, add, bluetooth, console, dash, disassemble, disassembled, expedition, expidition, ford, installation, kit, mobilease, trucks
