anti theft pats trouble codes
<TABLE cellSpacing=0 borderColorDark=#000000 cellPadding=0 borderColorLight=#000000 border=1><TBODY><TR><TD vAlign=top width=395>The engine does not start and LED remains off. <!--mstheme--></TD><TD vAlign=top width=504><!--mstheme-->1. Check PATS system fuses 2. If alarm is fitted check if LED functions for alarm: if not check cigar lighter fuse (also used for LED)
3. If not go to main dealer <!--mstheme-->
</TD></TR><TR><TD vAlign=top width=395><!--mstheme-->Engine does not start: LED flashes rapidly <!--mstheme--></TD><TD vAlign=top width=504><!--mstheme-->Leave ignition on until the LED starts to flash a 2 digit code: (sequence- pause-sequence) Check the following codes: <!--mstheme-->
</TD></TR><TR><TD vAlign=top width=395><!--mstheme-->Code flashes: <!--mstheme--></TD><TD vAlign=top width=504><!--mstheme--><!--mstheme--></TD></TR><TR><TD vAlign=top width=395><!--mstheme-->1:3 <!--mstheme--></TD><TD vAlign=top width=504><!--mstheme-->Key code not received. Is key screened by other keys or objects? Try different key: if okay then first key is faulty. If not go to main dealer <!--mstheme-->
</TD></TR><TR><TD vAlign=top width=395><!--mstheme-->1:4 <!--mstheme--></TD><TD vAlign=top width=504><!--mstheme-->Partial code only received. Try again. If not okay use different key. If not go to main dealer <!--mstheme-->
</TD></TR><TR><TD vAlign=top width=395><!--mstheme-->1:5 <!--mstheme--></TD><TD vAlign=top width=504><!--mstheme-->Key not programmed into PATS. Program key as above using master <!--mstheme-->
</TD></TR><TR><TD vAlign=top width=395><!--mstheme-->1:6 <!--mstheme--></TD><TD vAlign=top width=504><!--mstheme-->Faulty link between PATS module and EECV Go to main dealer <!--mstheme-->
</TD></TR></TBODY></TABLE>
I bought this vehicle at auction and only got one key....i finally tracked down the previous owner and got two more keys for the truck. i tried the additional keys but the theft light still blinks rapidly with no start. do i need to take to the dealer to have the pats system reset? I tried discont. and reconnect battery power, but did not help.
If you buy the Ford "electrical & vacuum troubleshooting manual." for a 99 Explorer you will probably be surprised by how easy it is to fix most of the electrical problems on your Ex.
But it looks like your only option for this problem is the-OUCH-dealer.
I dont think theres any easy way to wire around the electronic PATS garbage.
